Question about NEC MT1060R Multimedia Projector
Projector produces very low light.
This machine has a slightly blurred picture that has very low light being emitted from it. I have another machine (same model) that is in great shape. I attempted to brighten the image using the projector. I removed the bulb assembly and sprayed the inside with canned air. There is a small prisimed glass that is loose infront of the bulb assembly. Any help would be worth it to get this machine working.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
My recommendation is that since you have 2 of these machines and the other is working fine,
Pull out the lamp from the good one and place it in the faulty one.
Turn it on and check the projection quality if it is still blurry. If it is working good, then replace the lamp. If it is still blurry, a good cleaning to the lens on the projector may be a good idea.
You can also check the auto focus function of the projector and the cable that provides the video signal to the projector
You can get the manual from below link if you need to find out how to check the auto focus setting
http://www.necvisualsystems.com/Documents/UserManuals/MT860_1060_1060R_MAN2.pdf
Posted on Jun 03, 2009
  • Tualiapz
    Tualiapz Jun 03, 2009
    Please rate this if it fixes your issue.
Can hear sound but cannot see picture
Hi, if your LCD projector turns on and projects light with sound but not the picture on your computer screen, first make sure the projector is plugged into your computer. If it is, check your computer display settings. Go to "Control Panel" and "Settings" or "Windows Setup." Select "Display." Make sure it's set to appear on your laptop screen and the the projector screen. Most laptops have a "Fn" key dedicated to changing the output display setting.
If your projector turns on but emits no light or picture, replace the projector's bulb, often called the lamp. Most have a life of between 2,000 and 6,000 hours. Your projector may warn you when the lamp life is about to expire, although some models simply stop working when the lamp needs replacing.
Thank you.
Jun 06, 2012 | InFocus Proxima UltraLight DX3 Multimedia...
Blurring during realtime movement
Try a different USB port if you can.
Check the lighting, to make sure you do not have "low light" conditions, that will affect the picture in a similar way.
Check the focus ring on the front to make sure it is set right.
http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
Dec 18, 2009 | Logitech QuickCam Pro 5000 Webcam
The night setting results in blurry pictures
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Jul 15, 2009 | Nikon COOLPIX S200 Digital Camera
Blurred images
This is mainly due to the slow shutter speed selected by your CAM. in low light situations the cam chooses a slow shutter speed to expose the image adequately. Any shakes that may have caused during the shutter operation will cause the funny images.
use tripod or other kind of support to your camera while shootiing in low light (indoors) without flash.
Oct 11, 2008 | Olympus Stylus 760 Digital Camera
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Jul 19, 2008 | InFocus LP 600 Multimedia Projector
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Mar 30, 2008 | Fuji FinePix A330 Digital Camera
When Zooming picture it produces blurred or fuzzy picture
This is when zooming through your camera LCD I presume? For small screens usually banding and pixelation is common, if this happens also when the picture is zoomed in on a larger monitor like on your computer then the resolution you set for your camera is low. You can check for the camera setting and increase the resolution from for example 1024x768 to a much higher value and the fuzinnes (blur) will disappear altogether...
Feb 08, 2008 | Fuji FinePix F460 Digital Camera
HP-070
Works for a few months?
Is this a new device -?
Check with seller and or makers help site.
Lamps guaranteed for 90 days and Machine for 2 years usually
Jan 15, 2008 | NEC VT465 Multimedia Projector
DSC-T7 : Blurred images ?
I don't own a T7,but I have the P150 and S40. All these small Sony digicams have something in common;Sony uses 1/40 as the default flash shutter speed in low light conditions,while other makers use 1/60.You are more likely to get a blurry picture compared to other digicams you have previously used,unless you hold the camera steady (two hands). The other thing about these cameras is their lack of weight, coming in at a mere 134 g/4.7 oz. Light weight means you must hold the camera steady (two hands) or risk camera movement when you press the shutter. Again, the tendency with a small,light weight camera is to hold it with one hand while you take a picture,this leads to blurry pictures. The review for this camera is positive; a "Dave's Pick." - Just remember the flash range is only 5ft / 1.6m. http://www.imaging-resource.com/PRODS/T7/T7A.HTM
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Blurred images with no flash
First, try to get more light, particularly natural light (window); second, try using shutter priority (S mode), setting the shutter speed at not less than 1/50, faster if you are shooting motion/action (check the Properties of the blurred pictures that you've been getting in Camedia software - the shutter speeds are probably too slow because of the low light), and experiment with higher ISO settings (either 200 or Auto, not 400) though there's a trade-off in noise levels.
Sep 11, 2005 | Olympus Camedia C-3020 Zoom Digital Camera
NEC MT1060R Multimedia Projector Logo
251 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
