Copiers
Problem for Copiers
Generic problem for all Copiers
Mita DC-1205 Copier
By patkru on Oct 24, 2007
Require a manual for Mita DC-1205 copier. Was given old machine still in excellent condition and need to replace toner. How do I remove toner unit to replace and what toner do I replace it with?
Same Problem
Apr 29, 2009
-   What is the simlulation mode on the Mita DC 1255 To Adjust the Manual and Auto Exposure ??? -   Guest
Solution #1
posted on Oct 24, 2007
Not Rated)
copiers plus
Rank: Wiz
Rating: 84%, 56 votes
If you need a manual for it try looking on line for older copiers. Since that unit was built back in the mid 80s.The other person that helped you on the toner is exactly right.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
Answer
we have an HP Photosmart C4440 All-in-One, and the copy/scan features don't work. they will copy or... (More)
Answer
it has an error code 322.I took out the drum unit but upon returning it gave me the error code
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
