Question about ASUS P5VDC-MX Motherboard
Ram Dear Sir/Maddam I have a Asus P5VDC-MX supported rams are supposedly: Supported RAM Speeds400 MHz · 266 MHz · 533 MHz · 333 MHz But just read some put a 677mhz in and works fine.. My problem is I want to buy This ram that is high performance and need to know if it will work..I think not but I am no technician. KINGSTON HYPERX 4GB KIT DDR2 PC2-8500, KINGSTON KHX8500D2K2/4G HYPERX 1066MHz(PC2-8500) DDR2 4GB KIT (2x2GB) CL5 (5-5-5-15) RAM Power supply : Vdd: 1.8V ± 0.1V, Vddq: 1.8V ± 0.1V Double-data-rate architecture; two data transfers per clock cycle Bidirectional data strobe(DQS) Differential clock inputs(CK and CK) DLL aligns DQ and DQS transition with CK transition Programmable Read latency 5 (clock) Burst Length: 4, 8 (Interleave/nibble sequential) Programmable Burst type (sequential & interleave) Timing Reference: 5-5-5-18 at +1.8V / 5-5-5-15 at +2.2V Edge aligned data output, center aligned data input Auto & Self refresh, 7.8us refresh interval (8K/64ms refresh) Serial presence detect with EEPROM High Performance Heat Spreader PCB : Height 1.180? (30.00mm), double sided component Or.. 2GB Corsair (2x XMS2 1GB) TWIN2X2048-6400C4 PC-6400 DDR2 RAM, 2x240-pin DIMMs, Non ECC Unbuffered, 4-4-4-12 2GHz of DDR2 Memory SPD Includes Enhanced Performance Profiles (EPP) Implemented Using 64M x 8 DDR2 SDRAMs 100% Tested at 800MHz in High Performance DDR2 Motherboards Or..Simply I have to get standard ram ie. Supported RAM Speeds400 MHz · 266 MHz · 533 MHz · 333 MHz I have a 450 psu but that is regardless isn't it. Thanks in advance for any advice. Daniel.
    President:
  • 1,901 Answers
Your motherboard can take DDR or DDR2 RAM modules.
Crucial says: "Each memory slot can hold DDR PC2700,DDR PC3200,DDR2 PC2-5300 with a maximum of 1GB per slot." No sense getting 4GB since the max is 2GB.
You can get higher speed RAM (PC2-6400) because it is backward compatible.
I would go with the 2 X 1GB Corsair from the ones listed.
Or consider the options on Crucial's site. See this page:
http://www.crucial.com/store/listparts.aspx?model=P5VDC-MX
Two 1GB modules of DDR2 PC2-5300 run about $34 US.
(PS. Your 450W power supply will handle about anything.)
Posted on Jun 03, 2009
  • Wayne Mineard
    Wayne Mineard Jun 03, 2009
    Forgot to mention...you can't mix DDR and DDR2. You must use one or the other.
    Also, if you go to the Crucial site, click on "Show All" to see all of their upgrade choices.
    Thanks for using Fixya.
  • ASUS Master
  • 3,606 Answers
Can I use DDR2 memory with asus p5gv-mx
No you cannot.
This is the RAM specification for your model motherboard.
Memory Memory Type DDR SDRAM Supported RAM speeds 400 MHz • 333 MHz Max Supported RAM 4 GB
Jul 14, 2011 | Computers & Internet
Can asus p5gz-mx support 2gb kingston 800mhz ram
Click here to view the Specifications of your computer mainboard.
Unfortunately only 2 x DIMM, max. 2GB, DDR2 533/400 MHz memory modules are supported.
Meaning that it is not possible for the 2gb kingston 800mhz RAM to run, according to the Specs.
Sorry to inform you of this fact!
damnor01
Jan 23, 2011 | ASUS P5GZ-MX Motherboard
Can i install 2GB DDR2 in my asus P5VDC-MX? if yes which one is the best ?
Yes this motherboard supports up to 2 GUG of RAM and this are the choices of RAM speed that you can get 533 MHz • 400 MHz • 333 MHz • 266 MHz
Aug 16, 2010 | ASUS P5VDC-MX Motherboard
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
RAM capacity & Soundcard Driver can not be installed
this is the ram specs.
Max Supported RAM2 GB
Memory TypeDDR2 SDRAM Supported RAM Speeds400 MHz · 533 MHz what sound card do you have ?
Apr 01, 2009 | ASUS P5GC-MX/1333 Motherboard
PNY memory problems
sounds like its a ram frequency mismatch to be honest
altho they are both 200mhz there is a mismatch occurring
Mar 25, 2008 | Gigabyte GA-K8VM800M Motherboard
Graphic Card Support
From asus web you can get the required information.
To download the manual for your board click on the following link.
Click to download manual.
Thanks
iqbal
Mar 16, 2008 | ASUS P5VDC-MX Motherboard
ASUS P5VDC-MX Motherboard Logo
374 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
