Question about Sharp AR-M237 Copier
On a sharp arm 257 can you a drum unit or just blade and drum
What part number for drum unit for sharp arm 257 hard to ti find i can only find drum and blade thank you
    New Friend:
  • 91 Answers
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Posted on Jun 03, 2009
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 28, 2015 | Sharp Office Equipment & Supplies
Is there a toner catcher tray on this machine or is it trapped in the toner transfer belt?
Dear
the toner is flowing in the steps indicated bellow.
1- toner is transfered from the developer to the drum unit. ( the developer wiper blade is responsible for, clogged toner on the surface of the blade is main cause)
2-OPC drum unit. (the opc drum cleaning blade is responsible for this, the aging defect is most, may be the sharpness of the blade is over causing so or the waste toner drive shaft fails which cause back pressure of the toner is responsible).
3- ITB unit, ( the same as drum unit).
Hope rectifying the above may overcome the problem.
Thanks.
Mar 15, 2015 | Samsung Office Equipment & Supplies
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
HAVING TROUBLE INSTALLING A NEW TONER CARTRIDGE IN SHARP ARM 257. COPIER IS NOT RECOGNIZING IT...F2 04
AR-270NT is no longer accepted by that copier. You must use AR-310NT. Or, you have a bad chip on the back of your cartridge.
May 27, 2014 | Sharp AR-168D Black and White Copier
Error code l 4 01
L4-01 is a main motor lock error. More than likely something is locked up, rather than a problem with the motoer itself. Make sure the drum and Developing unit are turning freely. The Fusing unit binding can also cause this error. Turn the machine off, remove the developing unit and the drum. Put the developing unit back into the machine, close the doors and turn it on. If you can hear the motor run and there is no error code, then the drum is locked up, probably due to a flipped cleaning blade. The next area to check is the developing unit itself. Sometimes if the bushings go bad at the ends of the developer roller, it will cause a motor lock. There is a white coupling on the rear side of the developer unit. Turn it counter clockwise about a half turn, being careful to hold the unit level. There should be little resistance. If all seems O.K., then the Fusing unit is probably the cause. Also pull out the paper cassette and make sure nothing is preventing the pick up rollers from turning.
Aug 02, 2012 | Sharp Office Equipment & Supplies
Como desbloqueo mi fotocopiadora tiene este codigo h4-20. es una sharp arm-257
you have a problem with the fuser unit. Remove unit and check lamp and thermostat. enter sim 14 to reset code.
Jun 10, 2011 | Sharp AR-M257 Black and White Copier
It's a arm 257 copier with a code f5 -02 ran the
clean white surface under the glass and also mirror under the lamp be carefull to lamp
May 21, 2010 | Sharp AR-M237 Copier
Thick black line in all copies on sharp arm 162e
Dear,
when drum clean blade is weak then strongly can not clean toner,so thick black line in all copies.
Solve: Replace clean blade or service.If your copier drum life is zero,you can change it.
Nov 16, 2009 | Sharp AR-M162 All-In-One Laser Printer
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
Jul 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Copier Logo
274 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
