Question about HP Photosmart C7250 All-In-One Thermal Printer
Hp c7280 displays an error message B82C9410 on a blue screen with blinking lights, can anyone help
    Scholar:
  • 169 Answers
You can try a reset on the printer using the # and the number 6,holding them down
while plugging in the power cord at the back of the printer.if it still does not work
then you can try the same with the # and the number 9.If it still does not work,get
your printer serviced.
Posted on Jun 25, 2009
rockfixya
  • 679 Answers
SOURCE: HP C7280
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
JulesPCaut
  • 702 Answers
SOURCE: Uninstall HP image zone 5.3 installation - error installing hp c7280
Did you try an uninstaller program?
Also check out this article about fixing uninstall errors.
Posted on Apr 23, 2009
SOURCE: c7280 error msg 0xc18a0101
You press # * at the same time...... with the navegation arrows you go up to system configuration, with the arrown you navegate until you see error report...then you clear the error report.....then you turn off the printer...unplug everything from it.. unplug ac adapter from the wall wait 1 minute... then plug power back....turn on printer an Voila...is working
Posted on Sep 23, 2009
bandana_gyrl
  • 181 Answers
SOURCE: I have a printer ?HP c7280 All-in-one?a message,
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Jan 21, 2010
fbibeau
  • 66 Answers
SOURCE: HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Posted on Mar 04, 2011
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
I have an HP Photosmart C7280. The printer will not turn on. Every time I try a blue screen comes up on the display and then all of the lights start flashing.
1. unplugged the power cord for 20 seconds (actually went a little longer)
2. Held down the # and 6 keys together and then plugged the power cord back in (still holding the keys).
3. held down # and 6 for about 10 more seconds after plugging the power cord back in and didn't get any messages but once and release them It was able to turn the power on.
The printer then printed an alignment page
hope it works, if so do rate the solution
Nov 28, 2010 | HP Photosmart C7280 Laser Printer
HP PRINTER C7280 ALL IN ONE PRINTER. ERROR CODE ON printer LED SCREEN- INK SYSTEM FAILURE as above code.
Getting the blue screen on the printer LCD with the on/off switch symbol and the error 824C1500. Get a new and different error message each time I unplug the printer, wait a minute or so and then re-plug it in. I responds to no button pushing and will not turn off at all. Is there a simple fix for this problem or is it a throw-away?
for more help visit https://cbrtechsolutions.net
Oct 07, 2010 | Office Equipment & Supplies
The error light came on and I don't know whats wrong
What is the error light
Step one: Identify the specific printing problemIf your All-in-One won't print, first you need to identify the specific issue or symptom. What exactly happens when you try to print? Do you see an error message or do the lights on the printer start blinking (flashing)? Does nothing happen at all? Follow these steps to identify your unique printing issue before troubleshooting. If you can identify a symptom based one of these methods, make a note of the symptom, and then continue to the next step. Method one: Look for blinking lightsLook for any blinking lights on the front or top of the All-in-One. Sometimes just the power button can blink, or a small indicator light on the printer can blink, or a combination of buttons can blink all at once. Example indicator lights on the printer Attention lights Wireless indicator light Cartridge lights Error Lights c01890693.gif c01890694.gif c01890695.gif c01890697.gif c01890698.gif c01890699.gif c01890700.gif c01890701.gif Example blinking lights patterns
c01890702.gif Method two: Look for error messagesPrinting problems are usually accompanied by an error message of some sort, usually on the control panel display (if your All-in-One has one), or on your computer monitor. Check both places for specific error messages. Error messages might or might not be accompanied by an icon representing the error. Following are some examples of error messages you might see on your computer screen or control panel display.
  • c01890703.gif 'Printer is Offline '
  • c01890704.gif 'Align Cartridges '
  • c01890705.gif 'E ' (error condition)
  • c01890706.gif 'Document(s) pending ' (Roll your mouse over the product icon in the lower-right corner of the computer screen.)
Jan 16, 2010 | HP DeskJet F380 All-In-One Printer
I have a printer ?HP c7280 All-in-one?a message, ?Ink system failure, error: 0xc18a0201.?
Jan 11, 2010 | HP Photosmart C7280 Printer
HP Photosmart C7250 All-In-One Thermal Printer Logo
560 people viewed this question
Seeker5211
Seeker5211
