Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis francis milk steamer not operating
I turn the knob to steam milk and get nothing. It is like the knob is not connected to anything. There is plenty of water in the bucket and it has worked well for several years. The espresso part works fine. Thanks. I turn the knob to steam milk and get nothing. It is like the knob is not connected to anything. There is plenty of water in the bucket and it has worked well for several years. The espresso part works fine. Thanks.
  • 1,305 Answers
Steamer tubes can get plugged up with dried milk and/or calified water deposits in the tube.
With the machine unplugged, turn the tube up to check it, Clean it with a small guage wire.
Soak it in a small cup of vinegar, if needed.
Further cleaning, you can add a bit of vinegar to the water and steam it thru...
Let me know how it goes.
K
Posted on Jun 03, 2009
The steamer dosen't work at all. When the knob is
First you should remove the end tip of the steam hose and try to clean the steam holes with a pin. The steam should come frealy withou the end tip. If not then you shoul desasemble the steam tap , clean it and put it back together. The problem is only caused by dry milk or milk with chocolate. Even if you manage to have some steam then the problem can be solve by using the steamer warming just water in a glass and leave it all nigh long inside the boiling water in glass this will meld the dirt and will gos away.
Feb 09, 2010 | Rancilio S24 Espresso Machine
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
May 19, 2009 | FrancisFrancis! X1 - Stainless Steel...
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Steamer will not work
Make sure your milk frother is not blocked.
Aug 14, 2008 | Gaggia Titanium Espresso Machine
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Coffee tastes burnt/No steam for froth
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Feb 26, 2008 | Mr. Coffee ECM10
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Philips HD-5661 How does Foam maker work?
I recently acquired the same model of espresso maker. I have found that you have to turn it on, and give the water time to heat up before attempting to use the steam function. If you turn on the steam knob too early, it will shoot out a stream of water, so you have to wait till the water is hot enough... probably 3 minutes or so. I'm assuming that you already know that you just place the steam spout into a mug of milk to both heat it up and create foam simultaneously. -Tim
Sep 23, 2007 | Philips HD-5661
Overheat?
Typically it give the ventilate because insufficient amount of water/steam is comming through. A clog in one of the lines is usually the problem. This causes all kinds of headaches. There is nothing you can do so I suggest you do a search for an Authorized Saeco reapir center and have them do a service on it.
Dec 18, 2006 | Starbucks Saeco Italia Digital Barista...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
480 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
