Question about Samsung 225BW LCD Monitor
Screen goes bank after 2 seconds even if powder light is on
We purchased a 19" PC Monitors 13 months ago. Even if the monitor power light is on, the screen goes blank. If you then switch the monitor off and then on again, the screen comes up but only for about 2 seconds, then goes blank again even with the power light still on. PLEASE HELP!! Best regards Estelle samsung 225bw
5 Suggested Answers
GregL
  • 49 Answers
SOURCE: screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Posted on Jan 20, 2009
bunnydawg
  • 5158 Answers
SOURCE: screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Posted on Apr 16, 2009
pravinbhavsa
  • 348 Answers
SOURCE: Dear Sir, I am facing problem with my Samsung
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Posted on Mar 05, 2010
  • 732 Answers
SOURCE: i have Samsung SyncMaster 2233BW 22 inch LCD
nokerns, Internal ac to dc power supply problem might be cause of your "black screen of death" that plagues all brands of "cold-cathode-fluorescent-lamp" back-lit lcd monitors. If unit is covered by Samsung warranty, then contact Samsung and complain about "premature failure" of the unit's power supply and see if they will do a swapout for same model unit. As a side-note, you should also learn how to do the "black-screen-of-death" flashlight test that every owner of a ccfl backlit lcd monitor should know how to perform and understand the results of the test. Do some reading in the FIXYA profiles of "budmrtn" "buddymc" "12fixlouie" and other lcd monitor tech's here on fixya and also view some DIY repair video clips on YOUTUBE. You will truly be amazed to find out how prolific the BSOD problem is in the lcd monitor industry. Please let other know what you will do to solve your monitor's problem by doing a reply to this response. If this was of some use to you then please rate this response on fixya. Bye for now. 12fixlouie
Posted on Jul 21, 2010
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
My LGW2242T Flatron goes into power save mode within seconds of power up - so that only the LG logo appears on the screen - I dont even get a chance to go to screen saver options. This happened after I...
We need to narrow down the problem first, try this monitor with another PC to make sure i is not the PC problem, we do not want to take apart the monitor unless we have to. Please post back what you find first. See pictures below so you will knaow why if you will want to open up the monitor or not.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 31, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
19'' Suyama monitor
There are problem with internal component of Monitor might be EHT is faulty .Its better call vendor for repair
Nov 18, 2009 | Computers & Internet
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Apr 16, 2009 | Computers & Internet
Monitor goes black for a few seconds
Try swapping the monitor cable from the working monitor to the other video connection on your computer. Effectively reversing the connections to isolate whether your problem is the video card in your computer or the monitor itself. If you find the working monitor displaying similar symptoms, then check your video drivers and ensure that you have all power saving features, screen savers, etc... turned off.
Apr 06, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Monitor problem: screen goes black, then comes in scrambled
It sounds like this one needs component-level troubleshooting, probably in the power supply section. One or more backlights may be going out, too.
Dec 31, 2006 | View and View Technologies VNV AquaView...
Samsung 225BW LCD Monitor Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
