Please help Westinghouse top load washer
Ok the belt broke and we got a new one on it now its filling up watter and flowing over what could this be? and can it be fix?
    Sergeant:
  • 288 Answers
Check the outside of the tub there should be a small plastic bowl with a hose connected to it going up to the top. this is what shuts off the water when the tub is full. if the hose is not connected it will overflow water.
Posted on Nov 02, 2007
  • Washing Mach... Master
  • 909 Answers
Possibly belt damaged pressure switch pipe.or if not chech solonoid for defect.
Posted on Oct 24, 2007
SOURCE:
My washer fills with water, but won't spin, or agitate. I try changing settings, and all green lights turn on and shut off inmediately!
you have too take it apart and change the agitater belt it is broke you can usally get the belts at home depot or lowes hope this helps
Jul 25, 2009 | GE WJSR2070B Top Load Washer
TOP LOADER KENMORE WASHER FILLS UP BUT DOES NOTHING ELSE.
Sounds like belt is broken. Open front cover and look at belt, if broke replace. If not broke try unplugging for 2 minutes, plug back in then open and close lid 7 times slowly, this should reset the electronic motor.
Jun 05, 2009 | GE WBSR3140DW Top Load Washer
White Westinghouse model #MWX413REW The
Belts can wear out from: Overloading, old age, or stretching. Sounds like a new belt is in order for you.
To see the specifications and schematics for this machine, and how many belts it has, type your model number into the web-site "SearsPartsDirect" when you are asked to .
God bless your efforts.
Dec 21, 2017 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Clogged screen for White Westinghouse washer
the screen is located inside the water valve. you will need to take the hose of of the valve and take a small flat screw driver and pull the screen out
Cold water no flow on Kenmore front load washer
Check cold hose to see if it is clogged or the filter in the end of it is. Make sure water freely coming out from the tap. If that is all ok then replace the watter control valve on the cold side.
Dec 31, 2008 | Kenmore 43142 Front Load Washer
Spin cycles not spinning, does drain water before spin
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
Nov 04, 2008 | Washing Machines
WASHER FILLS WITH WATER THEN IT SITS THERE FOR AWILE AN DRAINS THE WATER BACK OUT DOESNT WASH OR SPIN JUST FILLS AN EMPTYS????
sounds like a belt problem. if you're not smelling burning rubber (belt) either the belt has come loose or broke
Nov 11, 2007 | GE WJRR4170E Top Load Washer
My washer will not fill, it just drains stright out so the watter will ran for three hours. I just did a load the night befor and everything was fine. I did not move or disturb the washer in any way...
Candy, check the drain hose, make sure it has a air gap and that it is not down too far in the drain. Sounds like a siphoning problem....Catriver post back.
Oct 05, 2006 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
