Question about Sony CDX-CA810X CD Player
Sony CDX-CA810X / CD-playback drops aux amplifier
I have auxillary amplifier plugged in for rear speakers using RCA audio-out plugs to connect from stereo to amp, and it works fine with tuner, but cuts off rear amp completely during CD playback. I switched connector plugs from rear set to the front set on back of stereo with the same results. For front speakers only I am wired straight from the main plug assembly. I actually bought two CDX-CA810X units (used) and both do the same thing. Does anyone know why the CD playback cuts off the aux. amplifier signal?
  • jerry_worrel Jun 04, 2009
    I think that may be it. Thanks a lot!
  • 87 Answers
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Posted on Jun 03, 2009
I have a sony cdx-gt45ip wen playing a cd or using the tuner my sub works but wen using the aux all bas dissaperes, the sub still has power why is this happening ?
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
Mar 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
I have a sony cdx-ca720x player and want to hook up a mp-3 player where and what do i need to install
you need a RCA to 3.5 Stereo cable and plug it in the rear of the radio. Should be labeled AUX IN!
Feb 17, 2011 | Sony CDX-CA720X CD Player
Hi is it possible to connect a laptop to a denon 700aedab for music playback
HI, very possible. Just follow this instruction:
All yo need to use for the connection is to get an RCA TO STEREO JACK HEAD (use the google image to see the type of cable).. Connect to denon 700aedab, make sure that the denon 700aedab is on either aux, tunner,video,etc. Those auxillary options on your denon 700aedab.
Connect the RCA into the aux of the denon 700aedab and connect the small jack head into the laptop ( where you plug in earphones),and play and enjoy your music.
If it does not play with aux try tunner, or video, one mustplay,and if it does ot play any, that means either the port of your laptop or the denon 700aedab port is faulty.
And don't forget to connect the speaker,because diffidently you will sure hear absolutely nothing with out the speaker.
Feel free to pass your comment .
Thanks for using fixya.
Jan 10, 2011 | Denon Audio Players & Recorders
HOW TO USE AUX
AUX is the auxillary terminal to connect any input to the set. You must connect to the AUX input an IPOD or any device , use the conttrol panel to switch o the AUX and play the source.
Oct 28, 2010 | Sony CDX-F5510 CD Player
The battery on my car ent dead and now my AIWA CDC-MP32 keeps displaying "please unplug auxillary plugs"
An auxiliary input allows you to select an external source and play it through the cd player's amplifier. It's often used for iPods and MP-3 players. Typically you just need an inexpensive patch cable that connects the headphone output from your portable player to the input on the CD player. After that you can select "AUX" as another source like CD or Tuner, and whatever's playing on the portable unit will be heard through the speakers.
Auxiliary inputs can be on the front or the rear of the CD player. Front aux inputs are typically 3.5mm stereo plugs, similar to a small headphone jack. Rear aux inputs can be RCA jacks or a 3.5mm jack. If you have a CD player with a rear aux input, a cable needs to be connected at the time of installation. Then the other end can be routed to whatever location in the vehicle you want to keep your portable player while you're using it with the CD player.
Front aux jacks are more convenient for quick connecting/disconnecting the portable player, but they tend to wear out over time.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Aug 19, 2010 | Aiwa CDC-MP32 CD Player
Where do i plug in the Aux cable
On the back of this system, do you see a group of RCA plug outlets? Marked IN and OUT? Phono IN? Phono OUT? Speaker IN? Speaker OUT? CD IN? CD OUT? Look for the one marked AUX IN or AUX OUT. AUX IN lets you connect a separate device, could be colored Blue, Green, White. Usually paired one over the other, RED over WHITE, YELLOW over WHITE, ect. If this system will accept an auxillary unit, player, ect, then it will have an AUX RCA type plug on the back.
Sep 26, 2009 | RCA RS2041 CD Shelf System
IPOD to Sony Xplod CDX-S2000 CD-R/RW EQ3
you car stereo doesnt have any aux inputs you can check up more on this site
http://www.crutchfield.com/p_158S2000/Sony-CDX-S2000.html?tp=5684&tab=features_and_specs
the rca inputs are for a pre amp or an amplifier
Jul 28, 2009 | Car Audio & Video
Aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Jan 24, 2009 | Car Audio & Video
Want to use ipod on cdx-f5710, how to fix it
use the aux lite input on the rear of the reciever. If it is a 3.5mm plug, you will need an extension with both ends male. One end in the aux port, on your head unit, the other end in the headphone jack of the ipod.
If it is RCA Aux lite, you need an rca-to-3.5mm adapter. Either item should be relatively cheap. $4-$5 USD
Dec 22, 2008 | Sony CDX-F5710 CD Player
Sony cdx mp40 bus audio in
ok dont know if you will check up on this but fm transmitters are all garbage. for true undistorted sound go to an electronics store and ask for a rca to headphone cable. then just hook it up to the rca input and run the cable out of either the unit or somewhere on the dash. this will alow for a true connection and if you buy a brand name cable i.e. monster, radioshack, sony etc. should sound amazing. always happy to help.
big c
Dec 25, 2007 | Sony CDX-CA710X CD Player
Sony CDX-CA810X CD Player Logo
365 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
