Not sure what you mean by reset. If piston driver is not returning this could be caused by a trapped/jammed nail or a damaged O ring quite often the one on the cylinder head. If gun has not been serviced for a while dirt may build up not allowing an adequate seal to be made. In this case clean gun thoroughly with brake cleaner paying attention to area where combustion chamber meets cylinder head also sleeve and piston ensuring the piston rings are not stuck in piston. After cleaning smear a thin coat of oil in the sleeve before putting piston back. DO NOT regularly oil these guns as the gas cell contains a lubricant.
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
-]0]0-
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
0-0-
