Question about HP Pavilion dv6000z Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
I noticed that my laptop power stayed at 6% even though I was on power for over two hours. I checked and noticed this...plugged in, not charging. Please help Mine is with the HP Compaq nx9600. I've seen similar problems with the 6000's and the 9600's. Keyboard and battery charging issues.
Bought new battery, still the same problem, no charge.
Posted on Jul 27, 2012
  • 197 Answers
If you charged up your battery up for 2hrs but didnt increase the percentage or didn't charge up at all it means that your battery is faulty. I have also a same case with you.
Send it to the service center near you and ask them to rplace your battery. Replacement is free if machine is under warrant.y
Posted on Jun 03, 2009
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
Hp Pavillion dv6000 will not turn when hit theon off button nothing happens
A lot of times these laptops are in a sleep mode (after a certain period of time which is decided by the windows or the user, the computers turn of the screen). I would start by pressing on the power button for a long time (about 1-2 minutes), then try all the basic stuff:
1. check the laptop's cable, if it looks okay or not, maybe there's a problem charging the battery.
2. try replacing the cable and the battery.
3. try removing the battery for about 24 hours.
update me if you have any developments
Oct 27, 2009 | HP Pavilion dv6000t Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
fixed it ( it is bios problem) but besure to down load the fix before formating or use win 98 to fix it
Jul 07, 2008 | HP 530i (Q6750A) DVD±RW Dual Layer...
Hp pavillion dv6000 battery problem
Check this site. You may fall into the category of known issues with this model. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=c01087277#c01087277_identify
If you fall into this category, they pay for fixing your laptop. It doesn't have to be under warranty.
Feb 27, 2008 | HP Pavilion dv6000z Notebook
I had a similar problem for over a week .... I wanted to smash my computer but I searched and searched and nothing that solved my problem, but I saw something about a bug where putting your computer on hibernation can cause a bug that makes the computer to not be able to recognize batteries, then I remember that before my problem came I put my laptop on Hibernation ...
So what I did to fix this problem was:
1 Unplug your battery
2 Start your computer with only AC power
3 Put your computer on Hibernation
4 Wait until is on Hibernation and Close the lid
5 Put the battery on
6 If the charging led is not blinking after a minute then is working, just turn on your computer to get out Hibernation
7 ???
8 Profit
Sorry for the bad English
Hope this might help for some people
Please bump this if it worked for you
HP Pavilion dv6000z Notebook Logo
302 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
