SOURCE: Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
SOURCE: Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
If you are saying that water is still coming out of the tub spout while the shower is on that is not a big deal a rather normal. If it bothers you a lot then you will need to replace the tub spout as the diverter in the spout has gone bad or is going bad.
Now if you are saying that the shower is leaking behind the wall when the shower head is being used then the threaded joint at the shower head arm is leaking and will need to be undone and put new pipe dope on the threads and reinstall it or it may be just lose and if that is the case remove it and reinstall it anyway.
If the water is leaking behind the wall and the above is not the case you will need to get into the wall and see where the leak is coming from and take the necessary steps to fix it.
Hope this helps and good luck.
