Question about HP Computers & Internet
Replaced the hard drive, won't reboot. give me blue screen- f1 to set-up, f10 system recovery. Does nothing.
PC will not boot up, can't find the BIOS settings to change the boot order.
    President:
  • 688 Answers
During the boot sequence hit delete several time and the cmos setting will pop open, make sure your drive is recognized.
set to auto detect and see if it finds it.
make sure your drive jumpers are set to master or slave. for the new drive master.if it's a single drive you usually remove the jumper connector.
make sure your master drive is at the end of the ribbon cable
change your boot sequence to cd cd cd and boot to the cd
then your windows cd will boot and you go through formatting and partitioning
once your done you will have to reset the boot sequence in the bios to boot to the hard disk.
Hope this helps good luck
Posted on Jun 03, 2009
  • 256 Answers
If you can get to the BIOS, the first screen usually has Date, Time and Disk information displayed. If there is no disks listed or your new disk is not listed, then it may be not properly attached. The power cable may not be makeing a proper connection. Also check both the motherboard and disk drive ends of the Data cable (the wide flat 40/80 conductor cable). The top menus should have an option called "Boot" or "Boot Order" where you can change it.
  • HP Master
  • 13,433 Answers
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
Motherboard for hp pavilion xt963 is there away to tell if its bad
It's very possible that your hard drive is dead. If you get a prompt when booting it such as F1 then the motherboard is working (so far), therefore it means the BIOS is ok and also that your CPU is ok if not nothing will show on your screen. If pressing F1 gives you boot options then select CD. If it won't boot from your CD force it by actually going into BIOS setup and selecting CD as primary boot drive then press F10 to save. (if BIOS setup options don't show when booting try pressing F10 or F8 and any other function keys after F1.
Make sure you have the installation disk. If the PC still doesn't boot or detect it you should try another CD/DVD drive, yours might be bad or buy or borrow a DVD/USB external drive and select it as boot drive in BIOS. Often I've seen that when booting if either the hard drive is bad or your operating system is corrupted it will prompt F1 because it cannot detect either. If OS is corrupted you will be unable to get to safe mode especially if the hard drive is bad, the recovery partition is on that hard drive and safe mode is a Windows program not BIOS.
After you've tried connecting a different CD drive to install your OS you should be able to at least see the Windows installation or whatever operating system you use asking to begin installing. If the installation fails then we move on to the hard drive; take it out and put a new one then try again.
If none of these help then there might be a circuit shorted out on the motherboard which can cause some things to work but not others although this is rare. Lastly I don't know what you meant by USB in your question because unless you have a bootable USB drive the system isn't going to do anything with it anyway.
By the way someone here mentioned RAM memory. BIOS should still show even if your memory is gone but some systems are quirky so this needs to be tested as well. I could go further if you had posted your system's specifications such as how many sticks of RAM you're using. Try dusting off your the inside of your computer with compressed air. Dust acumulation tends to cause weird behavior on a computer.
May 14, 2012 | Intel Motherboard
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
HP505N. Kids messed with computer and it shut down. Now it's stuck on the blue HP screen. F1 comes up with the entering setup box but nothing happens. F10 and using the system recovery disc won't work...
pres f 9 to choice boot menu. Or go F 10>go bios for set boot piority>and F 10> yes enter.if not work please re install xp .and create partion again ,because your kids can be delete the partion file (ntldr/boot.ini).
Nov 21, 2010 | HP Pavilion 505n (DC470A#ABA) PC Desktop
I have a HP Touchsmart IQ500 that is a little over a year old. It was working fine and I went out one day to come back and start it up to find it was only a blue screen with a few options.I found someone...
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Aug 20, 2010 | HP Computers & Internet
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
My computer wont boot properly
Try to check first if your hard drive is working. Just follow the steps.
  1. Load BIOS Utility by pressing any of the following keys upon booting or as soon as you have turn on your computer. (keys may varry depending on the brand or type of computer you are using but the following are the most common (del, f1,f2,f10) Just try any of the following.
  2. Under advanced option please check you hard drive settings. A numeric value should be displayed on the list or in some cases if you see AUTO in this option it means the BIOS automatically detects the hard drive. Just place your cursor on this option and press enter. The BIOS should react and will display the type of hard drive installed.
  3. If BIOS utility was unable to detect the hard drive and you still have a blue screen everytime you boot you will need to reinstall the operating system or run your recovery disk .
Jun 23, 2008 | Computers & Internet
HP PAVILION a305w
try getting into the bios and setting it to boot normally, turn off fast booting if its an option thats on, also, set your CD drive as the first boot devioce, then hard drive. Save and reboot, have CD in drive and just start hitting the F10 key as soon as it starts up, usually you hear a Beep when it detects that you are hitting the key for the boot options. HP pavilions where made to start and skip through the Post Process quickly to limit waitnig time, of course this sux when you want to boot from a cd.
You could try remove ing the BIOS Battery off the board and unplugging the system, wait a minute for it to discharge and put it back in, power it up and see if it lets you boot from CD.
Your bassically resetting the BIOS to factory defaults.
Also, i dont recomend buying HP Pavilions. i wokred on three seperate ones that a customer thought was a New machine ( this was back in 2001 ) but all the parts where 1995 parts, which means wghen they tried to upgrade to windows XP, XP doesnt have any generic drivers for hardware that old so nothing worked and yuo cant find any driver online that are that old.
Good luck anyway.
Feb 15, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
283 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
