Question about Vtech Cordless Phone Battery for 2429, 2498, 9110, 9119, 9152, 1712, 20-2438, 2101, 2121, 2151
Parallel set on phone wont turn off
On my vtech phone on the headset display it shows parallel set on, but both phones are not in use. We have had some storms this morning! Is there anything I can do to correct this problem? Thanks for any help... Jenna Moore it says that parallel set on but there isnt any phone in use and there hasnt been any storms
SOURCE: Not Registered Problem
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Apr 09, 2007
SOURCE: Vtech M6896 phones do not work
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
Posted on Jan 21, 2008
  • 121 Answers
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
I believe you can navigate through the menu and when you get to the ringer part push up on the navigation arrow. That should work. Thanks for using Fixya.Com.........Enjoy your evening!
Posted on May 30, 2009
  • 44 Answers
SOURCE: phone numbers not showing on caller id LED screen.
disassemble the handset (if you can figure out how to get it open). Flip the LCD screen over so that you can get to the end of the wire ribbon. You want the end that is connected to the phone, not the LCD screen. Carefully use a heat gun or hair dryer to heat the cable being careful not to melt it. Your goal is to melt the glue that connects the tiny wires to the electrodes. When glue is melted use a pencil eraser to press the wires so that they make contact again. Let it cool and try it out. It should work well after that. Put your phone back together.
Posted on Jun 28, 2009
This worked for the 7100, hopefully it works for other models:
When the handset says "not registered", it should still have a "menu" option. Select that, then the only choice is "register", select Ok. Now it says "searching for base", press and *hold down* the "locate handset" button on the base until the handset beeps and wakes up. Docs say this could take up to 30 seconds (it was about 17 for mine).
Posted on Jul 01, 2009
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
Aug 18, 2017 | Vtech Lands Phones
I dont know how to able the bluetooth of blackberry curve 8520??
Here are the pairing instructions for the Discovery 610 to your mobile device.
Bluetooth Pairing Instructions:
Look in your mobile phones manual for the section that describes how to set up a Bluetooth wireless connection.
1. Move through the menu selections on your phone until the phone display shows "Look for Devices," or equivalent, as a selection.
2. With your headset turned off, hold down the call control button until the headset status indicator briefly glows blue, then flashes red and blue. The headset is now in discovery mode and will stay that way for 30 seconds.
3. On your phone, highlight and select "Look for Devices", or equivalent, to activate the scan for the headset.
4. When the phone display shows the scan results, select "6xx Plantronics". The phone will continue to search for the headset.
5. When the phone display asks for a passkey, type "0000" and press Enter.
Your headset is now linked to your phone.
I hope this helps.
Good luck from Headsets Direct - 800-914-7996.
Aug 03, 2011 | Plantronics Bluetooth Headset 610 Wireless...
My Phones don't work. They only display PARALLEL SET ON. How do I fix this?
Try unplugging the device or pressing the reset button if available.
Mar 08, 2011 | Vtech CS5121-3 Trio Cordless Phone
How do i set my timer n1502
Link below shows timer and manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
Plug timer into outlet and display shows two parallel flashing bars and lights turn on.
Set timer to to turn OFF 1 to 9 hours after dusk by pressing selector button.
Hours will show on LED.
To select dusk to dawn, press selector until 2 parallel flashing bars show on display and lights turn ON
You can also take advantage of fixya phone support, for a price.
Fixya expert will download the manual and read the steps to you while you program the timer.
Dec 17, 2010 | Woods Outdoor Lighting Timer
What does parallel set on mean on a vtech phone
parallel i believe refers to the ability to use multiple handsets on one line and one call. This phone has the ability to isolate a telephone call so that only the original answering handset can tune into the conversation. If you only have one of these models then this setting has no real function.
Pls Rate This Post :D
Feb 11, 2010 | Vtech Digital Cordless Telephone VT-2568
What do parallel set on the phone mean
my phone has been stuck on parallel on for 4 days now and i cant remove i have removed battery unpluged entire phone for 12hours and still cant call out and no one can call me
Nov 02, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
New vtech phone model cs6229-3 headset keeps saying line in use
These phones look at the voltage on the line to determine if the line is in use.
Do you have any devices on the line that get power from the phone line? If so, they may be loading down the phone line causing this issue. If you have these types of devices on your line, try disconnecting those devices and see if the problem goes away.
Otherwise, your phone line may be defective. You may need to contact your phone company to get the problem resolved.
Sep 13, 2009 | Vtech Cordless 6041 Phone
Vtech CS5113 won't show on headset or base there is a new message
I have a CS5113 new 5.8GHz phone. It was not using some time. After that when i plugged , charging led is glowing on phone. it was charged 16 hours. but no display on phone. Please suggest the remidy.
Sep 07, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Mar 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Every handset is showing me connecting ...
I am having the same problem. I unplugged everything, and nothing changed. Phone #2 comes back sporadically. Has anyone gotten word from Vtech?
Jan 20, 2008 | Vtech mi6896 Trio Cordless Phone
Lands Phones Logo
641 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
