Question about Onkyo HT-S780 System
Step to steo connecting onkyo hts780 7.1 ch
Please step to step to connect subwoffer,i does not work
How to wire subwoffer to five speakers I've been told how to connect subwoffer to tv
i didnt tell you how to connect your subwoofer to your tv,i told you how to connect the audio unit to your tv,the 5 speakers AND the subwoofer connect to the surround sound audio unit,you DO NOT CONNECT SPEAKERS DIRECTLY TO TV.,
May 27, 2015 | Audio Players & Recorders
My AVR-E400 sub woffer not working through the Denton system
AVR-E400 has an RCA subwoofer output. This is a line level signal that must be connected to an ACTIVE subwoffer (has its own power amplifier) Also the source must contain subwoffer signal (5.1, 7.1, 9.1 surround sound etc) You will not get subwoffer signal from a stereo source such as audio CD, non-dolby type TV etc. Cheers, Don.
Dec 05, 2013 | Denon Audio Players & Recorders
Onkyo surround system. The subwoffer isn't making sound. I've tried all remote settings. No luck though. Any ideas?
Try checking that the wires are properly connected to receiver. Maybe the sub speaker is blown
Mar 12, 2013 | Audio Players & Recorders
I do not see any inputs to connect a subwoofer to my Onkyo A-9555 integrated amp. I would like to know if it is possible to connect it and what kind of subwoofer should I buy for that wit the best...
You amp has no OUTputs for a sub, but if you really want to attach a sub you'll need to get one that is self-amplified and accepts >>>stereo<<< High Level or Speaker Level inputs.
Otherwise your amp's volume control won't also control the sub's volume.
You would feed it full-range audio from the speaker terminals on your amp and its internal amp would use that to develop its own power output for the sub.
Here's one example.
Jan 29, 2011 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
No video when connecting wii to Onkyo TX-sr507 AUX
Did resolve the issue? I 'm pkanning to buy wii @ my home. Please suggest me.
I do use the Onkyo 507.
Jul 25, 2010 | Onkyo Tx-sr507 A/V Receiver
How do i connect it to a the subwoffer sw 50 ht
on the back of your receiver is a subwoofer pre-out, connect one cable here, and connect the other end of this cable to your subwoofer - line level in. (depends on your subwoofer and receiver) but that's how mine is connected. yours will be similar.
Feb 10, 2010 | Kenwood VR-505 Receiver
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
Jan 24, 2009 | Onkyo Audio Players & Recorders
No Sound
Tell me in details how you connect your whole home theater system.Step by Step.Video and audio connection please.
I need to know does it happen only on certain component(ex. dvd player?)
Oct 21, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Zone 2
if you have a main speaker system working properly, takea known good amp to ch2. wire the main pre amp out to amp 2 input.. turn both units on(no spkrs connected), fire it up. if the amp does not go into protect mode, turn ALL power off to the system.,connect one Spkr channel on A2, AND TURN THE VOLUME DOWN FIRS!!!!. pOWER UP THE SYSTEM AND SEE WHAT YOU GET.BE GENTLE WITH VOLUME SETTINGD! If ch 1 works, repeat procedure with ch 2 pre amp out.
Nov 11, 2007 | Onkyo TX-NR801 Receiver
44 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
