Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Refrigerator not cooling, pump running, flashes "34"
The refrigerator side is not cooling, although the freezer side is still freezing (-4F).  I can hear the pump running in the back, but the back is fully enclosed (I could remove the panels) so I can't see or feel the coils.  The digital thermostat display is flashing "34F", but pressing the temperature button once displays "42F", which is the actual temperature (I think).  No matter what action I take on the control panel, the display always returns to a flashing "34F".  Any suggestions?  Thanks!!
There are holes sort of that lead from the freezer to the fridge and sometimes they get plugged up
you should check where the cool air comes into the fridge section an make sure the holes are free of ice/ debris
Posted on Jun 03, 2009
    Novelist:
  • 103 Answers
Hi: When you removed the back of the freezer was there any frost back there? If so you are having a problem with the defrost heater ot timer. When frost builds on the back of the freezer it will block the airways so the fresh food compartment wont get any cold air from the freezer. The heater will be at the bottom of the evaporator coils. Usually a glass tube with a metal coil inside, check the metal coil for breaks. If broken replace it. If not find the defrost timer. Sears parts will have a diagram. I'm not up on Samsung but some of their pricey models have dual evaporators. Which will mean there is a problem with the electronics. I've never seen a complaint about the later though. If there is frost, melt it with a hair dryer, avoid the plastics on the liner. That way you can limp it along until you get the replacement parts. I hope this helps, Jeff
My freezer will not freeze or cool. I checked the compressor and us cool to the tough but the copper is very hot??? Help please
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Also, using a freezer to cool hot items or opening the freezer frequently will affect the... the freezer is running but not freezing is improperly packing the contents.
Fix a freezer not freezing but still cold - YouTube
? 1:34
www.youtube.com/watch?v=hCUewYVyiFQ
Aug 19, 2013 - Uploaded by Dave Here My freezer wasn't doing a good job freezing but there was ice on the back ... If not, approximately how often will I need to repeat the process?
Oct 19, 2015 | Refrigerators
My frost free freezer stops freezing although it stays cold and then I have to switch it off for more than a day before it starts freezing again
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool Refrigerators
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 10, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
I have a Whirlpool fridge freezer ART 731. The freezer is working fine but the fridge has started to get too cold and freeze the items inside although the control is at its lowest.
heatman101
Aug 27, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Not freezing but fridge is cool (veggie drawers are at 44 not 34)
your compressor is probably not running. if you see no ice build up in the freezer compartment, then the problem is most likely the compressor relay. although it could be a myriad of things, the relay is the most common.
Oct 27, 2009 | Maytag Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 12, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
205 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
