Question about GE Dryers
Electric egnitor for a gas dryer lights but does not stay on
General Electric Gas Dryer will ignite fule for 10-20 seconds but wont stay on
  • 6,784 Answers
Check the following-
Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Posted on Jun 03, 2009
Dryer model # GE DHDSR46GGWW igniter glows but no flame or indication of gas. At first when I hit the solonoid it ignited, but not anymore. I checked the connections, all seem ok. I figure the solonoid is...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[][
Sep 01, 2011 | General Electric DHDSR46GGWW Gas Dryer
My dryer turns on, will click then the fire ignites, but goes out after a few seconds, so it is not staying on, and it takes two and three cycles for my clothes to dry, is it the igniter?
heatman101
Aug 14, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Model MDG3500BWW gas dryer will ignite and burn properly for about 30 seconds, then the igniter will glow bright orange, then shut off without igniting the gas. It will continue this cycle of...
heatman101][
Aug 07, 2011 | Maytag MDG3500BWQ Dryer
My gas dryer KGYS750LQ has heating problems. The gas flame ignites and stays on for approx 15 second then goes out. The ignitor glows on and off but no combustion. Is this a problem with the two coils?
heatman101';
Jun 01, 2011 | KitchenAid KGYS750LQ Gas Dryer
Dryer is not drying igniter coming on but wont stay lit lites once in awhile
heatman101
May 24, 2011 | Whirlpool Dryers
I have a gas dryer and the trouble is it will ignite and stay for about 10 seconds then go out. The dryer will continue to run and about 15 minutes will ignite again stay for 10 seconds and go out. This...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 01, 2011 | Kenmore Dryers
Maytag Model # LDG510 - Dryer burner will not stay lit. Electric igniter glows but will not lite gas. Igniter cycles on and off.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Maytag Dryers
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Flame wont stay on
heatman101
May 26, 2010 | Maytag SDG3606A Gas Dryer
KEEPS SHUTING DOWN AFTERYOU START IT
check the igniter, maybe it is not hot enough anymore. it needs to glow white not orange. if it is orange change it.
Oct 24, 2009 | General Electric DWSR463GGWW Gas Dryer
Dryers Logo
108 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
