Question about Mamiya Cameras
Missing the crank handle on a Mamiya 645 1000
    Top Expert:
  • Mamiya Master
  • 79,024 Answers
The only place u may find one of these is used on ebay.
Posted on Jun 03, 2009
Mamiya RB67 Pro S: film counter does not advance, but the film does advance purchase another back same problem. Is there a switch that I'm missing??
If the problem is on the magazine's counter and if the spacing of frames is correct then the counter dial is loose. two screws on the outside front of the top of magazine, two screws in the film chamber hold the top cover. remove leather cover on winding lever loosen screw and remove. you can then remove the complete top housing to expose the counter mechanism.
Oct 30, 2013 | Mamiya Rb67 Pro S Medium Format Camera-...
Just got a 645= shutter "release jammed:, I put in new battery and also missing the crank arm, must have had a motor handle before. its like new, meter in prism works new battery,have old 645 J to...
if the shutter is jammed just off the device,and slightly pull the shutter door with your hand 3-4 times.apply a drop of oil on both the sides.and then on the device.and check it will work.
and for the replacement off the handle you will have to check on the old device that where are locks in the back you just have to remove that locks,also check for the hidden screws in the centre or back of the handle.which may be blocking it to be removed easily.
thanks.
Oct 11, 2008 | Mamiya Cameras
Don know off manual film crank
What about the film crank? You want to know how to take it off the camera? What make and model camera?
Jul 12, 2013 | Mamiya Cameras
Mamiya C3 film advance
Hi there,Here's a link to a PDF instruction manual of your camera body.
http://www.cameramanuals.org/mamiya_pdf/mamiya_c3.pdf
It is possible that the crank handle is missing, as it is a removable piece. Bring your camera to a camera shop and see if they have a box of old parts to replace it with. You can either use a regular round knob, or (if you're lucky) one with a crank on it.
Aug 01, 2012 | Mamiya Used C3 Professional Tlr Body...
Hello. I just got a Mamiya C330, looks really nice but I note that the little release botton in front of the camera is inside I can;t take it out. my question is this could affect to take picture or I...
This button you speak of is an alternate way of depressing the shutter it is also a way in which you can use a shutter release cord to take pictures. the button itself is not meant to come out of the camera. Once you load your film or 2 empty film spools (to test to see if the camera is working properly) into the camera and wind the film crank then you will be able to depress that button and fire the shutter.
http://www.butkus.org/chinon/mamiya/mamiya_c330f_prof/mamiya_c330f_prof.htm
Aug 10, 2011 | Mamiya C330 F Professional TLR Film Camera
I just purchased a used back roll film holder for my Mamiya 654 Pro TL, and I cannot pull the dark slide out. This dark slide has a blue handle, where my other back's dark slide has a red handle, and...
It's been a while since I used a mamilla 645, so forgive me if this is wrong, but I seem to remember the dark slide would only come out with the camera wound on, ready to take a picture.
Dec 26, 2017 | Mamiya 645 Pro TL Medium Format Camera
The mamiya 7 shutter does not trigger after each cranking of the film advance.... it misses about 2 frames out of 10. any idea why this is happening and how to stop it?
Very likely that some of the teeth on an internal gear are broken, or stripped. It could have been jarred or over time, just gotten brittle if its plastic.
Another poss. is that the shutter lubrication could have dried out = more resistance = snap.
sounds like it gonna require taking apart. At Minimum, a CLA, otherwise, parts too.
Oct 20, 2009 | Mamiya 7 II Medium Format Camera
I have a mamiya 645 pro camera I can't remove the old film spool from the camera ? JoAnn
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
Jun 15, 2009 | Mamiya 645 Pro 80mm F2.8 N/L Lens
Mamiya 645 Super Replacement Parts
You can probably order direct from Mamiya, here is the contact info: Mamiya America
Mar 26, 2008 | Cameras
Cameras Logo
20 people viewed this question
Top Mamiya Cameras Experts
Tony Parsons
Tony Parsons
Allen Showalter
Allen Showalter
Level 1 Expert
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
