Question about Mitsubishi WT-46805 46" Rear Projection Television
The Green light of Death
To the TV Gods...
Have a Mit. WT-46805 and it stop working about 2-3 days ago. Push the power button to turn it on and it just makes a click like it is trying to catch but no good. Any clue..?
Thanks.
MM
I was told for mine that the cpu is keeping a relay from turning on.the shop said they would have to find out what is makeing the cpu want to do that. could be a $100 - $1000+ repair.
Posted on Oct 27, 2007
No picture
your projection bulb needs replacement i think...if i got you clearly!
Aug 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
I have a WT-46805 Mitsubishi rear projection tv. The screen was accidentally pushed in and now has a crease. It was also missing the protective glass in front of the screen. I also have a broken model...
Check following image taken from related service manual that shows how to take off front screen from WT-46805 tv.
Hope this info will help you.
Please click HERE to download service manual copy, if required. It has schematics, parts list, exploded views and all technical info of WT-46805 tv. (service manual is available for 2 days only)
Thanks.
Nov 13, 2010 | Mitsubishi WT-46805 46" Rear Projection...
I am attempting to connect a Verizon Fios QIP6200-2 HD set top box to my Mitsubishi WT-46805 HD TV using the Y, Pr and Pb RCA connections (no HDMI port on TV) I cannot get any HD channels to work.
The set will have two component inputs, one is NOT HD.
You want to connect to the DTV input which if you look from the back will be marked 480/1080 I .
Also double check the connections to be sure blue-red-red and green to green.
SD TECH
Aug 18, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Push power button and it clicks once then green light goes out and then clicks again and then nothing happens
Do the self check the model indicated has:
When power light goes out on the front of the set press and hold both the Menu and Input (device) buttons for at least five seconds and then release both buttons.
Watch the power light closely as it will blink a two digit error code: 2 blinks and a pause followed by 2 blinks is the most common one.
It will repeat the code about 5 times and then to get it to do it again you would have to unplug the set and attempt to turn it on again etc.
Let me know what code you find and I will tell you what it means and what kind of trouble you have.
SD TECH
May 01, 2010 | Mitsubishi WT-46805 46" Rear Projection...
The picture on my tv (mit. 1080) is made up of
Convergence ICs Two of them STK392-570 ,they are big black ICs,Replace with same Number on ICs.You can order them at MATS 1-800-628-1118.
Aug 07, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Wt 46805 wont start up
Good Day, you'll;
Try the following:
NO POWER. NO RELAY CLICK 1. CHECK FOR 5 VDC AT PIN 9 OF IC700 (AC-OFF) IF MISSING CHECK PC901 PART # 268P058020, ON THE POWER PCB. NO POWER. RELAY CLICKS 1. CHECK Q501 (261P071010), Q502 (260P561020) AND Q503 (260P788010). IF ANY OF THESE TRANSISTORS ARE SHORTED OR LEAKY REPLACE IT INSURE THE FOLLOWING CIRCUIT CHANGE HAS BEEN DONE. REMOVE J58 FROM THE PCB-MAIN. USING AN INSULATED JUMPER WIRE, SOLDER A 22 OHM 1/4W RESISTOR BETWEEN PIN 4 OF THE RELAY K9A30 AND THE J58 HOLE NEXT TO PIN 1 OF CONNECTOR DQ. DRESS AND INSULATE THE JUMPER AND RESISTOR TO PROTECT AGAINST SHORT CIRCUITS. INSTALL A .01 UF 50V CERAMIC CAPACITOR BETWEEN THE COLLECTOR OF Q510 AND THE GROUND LEAD OF R502. CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010.
Good Luck, big IRISH.
Oct 15, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Open Questions:
See all Mitsubishi WT-46805 46" Rear Projection Television Questions
Mitsubishi WT-46805 46" Rear Projection Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
