Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Cant start it up
Batteri is ok and olso the memoricard,(must the lense sit on?)
There is a sensor that tells the camera if the memory card flap is open. Perhaps the sensor is stuck, the flap is open, or the memory card is improperly inserted. The lens does need be on for the camera, and locked into place, so ditto for the lens and its' sensor.
Posted on Jul 05, 2009
Ex-s770 start to turn on then turns off
hi the problem is going to be with the lense motor jaming and not letting the lense come out all the way to switch the camera on to take pictures what should happen is the lense should come out all the way the go in just a little bit so that it focuses it does this so that it resets the lense for when the screen comes on.
If the camera has been put down with the lense out and any pressure has been put on it and put the lense out of line then this will cause the problem your having.
But the even bigger problem is their is no way of repairing it as most shops dont repair the smaller digital cameras so the chances of getting someone to look at it is a bit remote.
The only thing you could try is when the lense comes out try and pull it gently a bit further and see if that lines it back up as their a sensor on it so that when the lense comes out it switches the camera into the mode to take pictures but you can acess the pictures with the lense in so you know the batterys fine and that the circuit board is also fine.
It just the lense i know you cant get replacement parts for your make and model the only spares you can get is batt and cards so gently pull the lense if you can you cant damage it anymore than it is anyway can you.
Let me know how you get on ok.
Jan 29, 2008 | Casio EXILIM Card EX-S770 Digital Camera
I'll start from the beginning... 91 cbr250rr sat for over 6months then wouldn't start. Didn't have a choke so decided to put in new one while doing that decided to replace spark plugs and new leads, (had...
Is your choke working OK?..is there a spark at plugs take a lead of and put a good plug in the cap hold the plug against metal block to see if a spark is present use gloves or a pair of pliers to hold plug or u will get a big shock,this will olso check ur leads check each one in turn ,the firing order chud be in hand book
Oct 29, 2013 | Cars & Trucks
I just bought a 92 jeep cherokee ran beautiful . now it just sits there cant get it to start . battery was dead replaced still wont start . cant tell if its the ignition or the starter.
I'm assuming the starter is not turning the engine...check the small wire on the starter for 12v with key turned to start. If no voltage there, check ignition switch and neutral start switch. (voltage in, voltage out)
May 09, 2009 | 1992 Jeep Cherokee Sport
My pc wont restore to an earlier date olso i cant install or uninstall anything can you help
# 1 make sure system restore is turned on.
Go to My computer icon - right click go to properties - system restore tab.
# 2 make sure your windows installer service is started.
Go to start - control panel - administrative tools - services - windows installer
Let us know if that takes care of it. get back to one of our experts if not.
Thank you
Mar 06, 2009 | Acer Aspire 5102WLMi Notebook
Casio Digital Camera ex-s770 will not open
Hi, this is a problem alot of people get having with this type of camera.
It could be one of a couple of things first check the battery is fully charges as a faulty battery would cause this problem, do you have a switch on the camera that lets you see the pictures stored on it without opening the lense, not all makes and models do this some have switch you can slide and some is just push button the push button you cant do this.
So if yours is the push button one then the only thing to try if the battery isnt the problem is looking and removing anything thats caught in the side of lense.
Ok try removing battery and any mem cards if you have any in it then bang the camera firmly into the palm of your hand sort of shocking the camera to dislodge any thing thats stuck in the side of lense do this few times then replace battery and switch on usually this solves the problem.
If not then when you switch camera on grab the lense and help it come out taking it past where it gets stuck be gentle try this few times and see if camera comes on.
Once the lense is passed certain point the camera should come on.
So give that a try it does sound like something is jamming the lense so try pulling it out gently only do it when its supposed to be coming out when it trys to go back in let go again try this few times.
Failing this then the problem could be that either the camera has been put down with the lense open and forced the lense motor damaging it or the other thing that people tend to do is switch camera on acidently whilst its in pocket or case so that it switches on but the lense is blocked from coming out this causing damage to lense motor.
If the problem is in fact the lense motor then their is no way of getting this repaired they just dont repair these and you cant get the parts like lense motor no camera shop will even look at them as you cant get parts and also price of repair would cost more than replacing the camera.
Also check to see if your lense turns round as its coming in or out if it does this then try turning the lense as its coming out.
Let me know how you get on ok and ill try assist you further
Feb 22, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
239 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
