Zebra TLP 2844 prints fine at workstation (local printer) but when trying to print from Server via shared Zebra the barcode does not print and the formatting is screwed. Tried to move Zebra to the server directly (local) and still has problem....please help!
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation.
The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
Was this helpful?
Yes
No
Popular Solutions for Zebra Eltron TLP 2844 Thermal
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each...
(More)
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each label. First one print all right, but next ones are not on the tag, printer leaves some gap. i have removed gaps between labels as well in printer properties, but still nothing. please if you can let me know how can i calibrate jewellery tag in tlp2844 Thanks
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to...
(More)
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to print the same bar code horizontally it does not print all the lines. Thought I had printer head problem but the same happens with the new one.
