Question about Mitsubishi VS-6043 60" Rear Projection Television
No picture and thumping sound
Picture suddenly scrambled with red and blue lines then went out completely. It started making a thumping sound and now thats all it will do when you turn on the power. Any suggestions.
  • gkcruz Feb 05, 2008
    TV was working Fine, then it just went out with a thumping sound and no picture.. Any help would be appreciated. Or should I thrash..Thanks...
I just had the same problem with my TV and looking on the web I found a site that helped. The site was The entry said Raster NO GO / Pulsing sound from speakers / Poss ant relay clicks in time to the pulsing. It recommended replacing C816 and C5a28 (100uf /200v Caps) C5a03 (4.7uf / 200v cap) My set did not have the ant relay clicks and I could not fine the C816 cap on the circuit board and I didn't have the schematic. I found the C5a28 and C5a03 caps about the middle of the circuit board in the same circuit (around the metal L shaped bracket). The C5a28 cap was bad and the C5a03 cap was fine. I replaced the C5a28 cap and the set works fine now.
Posted on Feb 17, 2008
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 17, 2014 | RCA MM36100 36" TV
I have a Panasonic HDTV and suddenly the colours went double!
hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
Feb 02, 2010 | Panasonic Televison & Video
Hello, all of a sudden the tv made a fizz out sound
Souns like bad HV transformer. Remove thedeflection board and send it to PTS for rebuild. At this point there are also other components that have failed.
Jan 12, 2010 | RCA D52W23 52" HDTV CRT TV
Picture keeps getting all scrambled
sounds like a problem with the main board and or av connector cord. contact vizio and let them know you are seeing some red pixelation. some parts on vizios carry lifetime warranties, it has been my experience that this is a covered issue. hope this helps.
Apr 07, 2009 | Vizio 42 in. LCD TV
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
No picture or sound,clicking in back and speakers thump to clicking noise
Tubes are messed up, to fix is REALLY expensive, trash it or part out what can still be used.
May 21, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
