Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer stopped spinning,timer still ticking,cannot get to restart.
Dryer stopped in the middle of a load.Timer still ticking like normal but cannot get the drum to spin.
Kenmore 600 will not spin, power is running to the appiliance,belt is secured. Need help
Posted on Jun 09, 2009
    Problem Solver:
  • 14 Answers
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Posted on Jun 03, 2009
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
Will not start but its making a ticking sound
Electric or gas dryer?
Depending on where the ticking sound is coming from, without more specific information, many dryers use a timer within their dial for timed drying. If the switches are malfunctioning, the ticking of the "timer" can still continue.
If you can hear a whirring sound, which would be the motor, then it may be the drive belt. If this is the case, then the ticking of the timer may be more noticeable due to it being quieter without the spinning drum.
If you have a gas dryer and the ticking is from below, then it may be the ignitor that's faulty. However, that shouldn't cause your dryer not to turn on. It that case the dryer would spin, but not get warm.
With more information, I may be of better assistance.
Feb 14, 2012 | Dryers
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
Dryer stops in the middle of cycle. It is not the door switch
There's not much here to work with. Is your dryer gas or electric? Do any of your clothes get dry? When you check inside, does if feel like it was warm when it turned off? How long does it run? My first guess would be the cycle timer. But you need to note if the drum was actually spinning and if the heat came on. If so, and everything was normal before it failed I'd go with the timer. If not ,there is another issue like a a safety switch for gas dryers which will not open the gas valve when the glow bar doesn't come up to temperature. Lastly, note where the dial points when it fails and most modern dryers have other cycle dials. Try one of those and see if it stops there too. You might just have a dead spot on the time because that is what you always use.
Apr 22, 2010 | Whirlpool LTE5243D Top Load Stacked...
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
Hi,Dryer wont restart
def. sounds like a bad or failing motor situation... motors cost anywhere from 125 to 200 dolloars... not too hard to replace though....
Sep 24, 2009 | Whirlpool LER7646E Dryer
Maytag dryer
you need to check the door switch and the main fuse inside the dryer on the blower box,let me know what you find-mike
Oct 29, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
271 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
