Question about Micro Pro 7599 Iron
Rowenta Iron Iron will not heat up...........DE 871, Rowenta.....What type of screw driver do I need to take iron apart.Is it very expensive to fix this iron, or will it cost more for parts than the iron is worth.Thank you.Beck
These are called tamper proof screws and you have to get them from the manufacturer. You have to be an authorized service center to get them. There were too many law suits aganinst the companies so they placed these special screws on the units so the do-it-yourselfers can not open them. I think they just do not want the units repaired and this is their excuse. They would rather have you toss the unit and buy another one. Sorry I can not be of more help.
Posted on Jan 14, 2008
ROWENTA DE 871 WILL NOT GET HOT
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Mar 17, 2011 | Rowenta Irons
How to disassemble a Rowenta DE-871
First remove screw the on the back of the iron. Next pull out on the fill tub on the front of the iron. Pliers might be needed. Another screw will seen at this time. Remove this screw and the sole plate will separate from the top portion of the DE 871.
Oct 02, 2010 | Rowenta Professional DE871 Iron
Rowenta iron won't heat
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 10, 2010 | Rowenta Professional Luxe DM880 Iron
Rowenta surfline iron turned off and won't go back on.
heatman101
Jan 27, 2010 | Rowenta Surfline Iron DE-333 Iron
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
Apr 12, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta iron model 871 series b shows rust while ironing
My iron spits rust spots on my cloths and need cleaning. I lost the manual in a move. I need help.
Thanks
Shirley
Mar 18, 2008 | Black & Decker D2030 Iron
Water Leaking
The seal between the top and the bottom plate has lost it's integrity. First try tightning the 2 screws on the underside of the iron. If that doesn't fix the problem, then you will need to take the iron apart and fix the seal. That will require you to remove those 2 screws and also a third screw that is up by the toe of the iron underneath the sprayer. You will then need to slowly pull the 2 pieces apart becasue the seal is made of a sticky rubber substance. Once you get it apart, you can then distribute the seal material to cover the bad area. Then just put it back together!
Dec 15, 2007 | Rowenta DZ1700 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Micro Pro 7599 Iron Logo
212 people viewed this question
Top Micro Pro Irons Experts
Marvin
Marvin
Are you a Micro Pro Iron Expert? Answer questions, earn points and help others
