Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
My Emerson EWL20S5, 20 inch LCD TV shuts off after a few seconds of turning it on.
I found this solution..
"If this happens right away or after only a few seconds, there is a 3 terminal voltage regulator with 7805 in its part number that may have a low output voltage rather than 5 volts."
Is there an online schematic, or how to pictures, for someone who likes to see what they are about to get into?
  • 1 more comment
  • Rocky1789 Dec 18, 2007
    comes on for a few seconds then shuts off, while on everything works
  • Kerfir Mar 20, 2008
    Problema que presenta: enciende pero se apaga a los 10 segundos.
    Posible solución: Se le hizo una inspección a todos los circuitos y al board y todo luce correcto. Luego procedimos a verificar el IC606/UTC 7805, y los transistores Q401/C8481, Q601/ K3869, Q603/C2120, D647/, KIA431625.
    También los capacitares C610/100:F/200V, C611/150:F/200V, C632/22:F/100V, C631/2200:F/25V, C633/2200:F/16V, C636/220:F/50V, C637/470:F/16V, C634/1000:F/10V, C650/330:F/25V, se reemplazo C649/470:F/16V.
  • Anonymous Oct 07, 2008
    shuts off after a few seconds.
El TV no enciende y desconecte la señal Protect 1, enciende pero la parte inferior de la pantalla no presenta información nitido o es muy poca la información. La power supply esta bien, solo el voltaje panel -6 esta bajo, alrededor de 3,5 v. el audio esta bien¿que puede ser?.
Posted on Aug 28, 2009
    Problem Solver:
  • 8 Answers
Ok, my tv was doing the exact same thing. What turned out to be wrong was one of the florescent backlight bulbs was broken. The tv was given to me, so I'm not sure how it got broken, but replacing the bulb repaired the tv.
This is not an extremely hard repair, but you have to be careful.Doing this repair entails disassembling the entire screen assembly. If you have any doubt at all about doing it, get a pro (like me). Getting a new bulb was not hard for me because I have several of these units in my shop with bad LCD screens; it may be a little harder for the general public.
I hope this helps.
Steve Wright.
Posted on Dec 19, 2007
  • spearslynn Sep 21, 2010
    dude where can i get a florescent backlight bulb for my unit ?????
  • Steve Wright
    Steve Wright Sep 21, 2010
    These sets are made by Funai. You can try reaching them by email at:
    Good luck,
I had the same problem got the tv for free so i just opened the back mine was the top inverter i clipped the "protect 1" wire with clippers and bam good as new a little dim but i havent figured that part out yet how to brighten it
Posted on May 31, 2010
This TV has a network of diodes connected to a PROTECT-1 line monitored by the control IC. If any circuit pulls this line low, the control IC turns the system OFF. The diodes act to isolate all the circuits from each other, its called a diode-OR circuit.
You can troubleshoot by opening a diode which disconnects a circuit from pulling the line low. I had a hunch the EL backlight board was bad, so after opening that protect line the power stayed ON.
I found a bad .068uF 250V cap on the transformer primary, it measured .002uF. I've replaced the cap and the other two on the other transformers just for good measure.
It probably took more time than the TV is worth, but my friend's Mom will be happy, and thats worth it.
I hope this helps, look around for the service manual, it can be found online.
Posted on Jan 15, 2008
Hey sewright34, i know someone who is having the same problem, is there anyway to get parts from you?
Posted on Jan 03, 2008
No.emerson tv.turn it on it shuts off.takes about 5x's to stay on
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
Apr 27, 2014 - Uploaded by Keith Fox I demonstrate in this video how to repair a Sanyo by swap out the Analog power board on a 42 inch. This IC chip ...
Sep 27, 2015 | Televison & Video
Why does my tv turn off by it's self after a few
Either a power board problem or something in the set is pulling the power voltages down---if under 26 inches it may not be fixable.
Mar 19, 2012 | Emerson Televison & Video
Hi my son got a 19inch emerson tv for his 2nd birthday and now anytime it gets plugged in it flashes different colors and the buttons does't work and the only way to turn it off is to unplug it!! can this...
Press the the cursor key up followed by down and power the TV off with the remote or the TV itself. Please use the original remote for this. Unplug the TV for a few seconds...replug and power the TV on. The second thing to the cursor key left followed by the right key. Power the the TV off with the remote or the TV itself. Unplug for a few seconds...replug and power up the TV. Some of these TVs left the factory in the service mode. The fix is pretty simple. Thanks asking and show a few hands of support!
Feb 14, 2011 | Emerson LC195EM9 19 in. LCD TV
I have an Emerson LCD Flatscreen, model BLC320EM9 A. When I try to turn it on, whether it be with the remote or with the button on the TV, the green light indicates that it's turning on for a few seconds...
Tries tv unplug,replug it back like about an hour later.The tv now it resetting itself back to factory setting should work again.If have the same problems,the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like, to buy a whole refurbish power supply board for the replacement.
Jan 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My 32 inch emerson powers up and cuts off after a few seconds.
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again. d66cb18.jpg
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If you have some electronic experience, if you can find and purchase a Service Manual at It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Sep 10, 2009 | Emerson LC320EM8 32 in. LCD TV
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
Westinghouse lcd tv 46 inch
take it to a servicer. you may have a bad inverter board.
Jan 23, 2009 | Televison & Video
Emerson 32 inch lcd
i have your answer!!!!!!!!!!!!!!!!
use the PRODUCT WARRANTY call emerson and have it sent back, then your like oh wow it works like new( and it will be a new one) yay thank you so much guy on the net for telling me about the PRODUCT WARRANTY
Oct 21, 2008 | Emerson EWL3706 37 in. LCD Television
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
1,287 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
