Home | Viking | DFUD042 Built-in Dishwasher | Viking dishwaser tur...
Viking DFUD042 Built-in Dishwasher
Problem for Viking DFUD042 Built-in Dishwasher
Viking dishwaser turns on, but I can tell that it is not cycling.
By kly2002 on Jun 03, 2009
It turns on and doesn't cycle and shuts off in a couple of minutes. Water remains in the bottom of the dishwasher. I pulled the filter out of the bottom and it is clean.
Tried all of the different settings, but nothing changed.
Best Solution
posted on Jun 03, 2009
Very Helpful)
localwonder
Rank: Guru
Rating: 92%, 2683 votes
Check the following to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Viking DFUD042 Built-in
Questions and Unsolved Problems for Viking DFUD042 Built-in
Do you recommend Viking DFUD042 Built-in Dishwasher?
Answer
Answer
my dfud 042 will not start wash cycle. It makes a ticking sound two or three times and will not... (More)
Answer
need to locate part number pd120064 for a viking dfud042 dishwasher
Answer
was going to buy this dishwasher - but see alot of bad reviews - have you had many people... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Viking DFUD042 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
