Question about Intel D865GBF Motherboard
Front panel audio failure-DG33FB Intel mainboard
Hello friend,
My problem is , my Intel DG33FB motherboard's front panel audio is not working whereas the rear panel works just fine.The front panel audio output does not recognize any audio devices,whether it is a headphone or other speakers. I have tried changing the cable that came with my chassis with another one-no hope so far.The sound codec is HDA. I have downloaded the latest audio driver from Intel's download side and installed too. I didn't help.
Friends,is there any solution? Thanks in advance for your kind assistance.
    President:
  • 2,351 Answers
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Posted on Jun 03, 2009
  • Mike Peluso
    Mike Peluso Jun 03, 2009
    Oh & change your bios setting from AC97 to HD if & when you hook up the front audio panel.
I pulled out powe cables for switch ledlights and reset, i dont know how to put it back
Hello visit gigabyte here:
http://www.gigabyte.com/support-downloads/support-downloads.aspx
And enter the mainboard number, to download the manual.
The front panel connector looks like this:
Or like this:
It depends how old the mainboard is.
Best of luck
Apr 21, 2013 | Intel Motherboard
Frx780m front panel connectors
Hello it would be nice to know what, brand the mainboard is.
But i think acer uses intel mainboard now.
The front panel connections probably look like this:
It should be named "JFP1" on the mainboard.
The acer support site can be found here:
http://us.acer.com/ac/en/US/content/drivers
By selecting desktop, model number, and windows system.
But the manual does not have detailed pictures or info, of the mainboard.
Hope this will help you
Feb 03, 2013 | Acer Computers & Internet
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
How to find model no of graphics card
I'm not quites sure what you need. I know this motherboard is an Intel model and that it has the graphics on the board.
It you need drivers and drivers or information or guides for this board, please copy and paste the link below into your browser that will take your to the Intel support page for your model Intel mainboard.
Select the type of operating system you have and then you can dowbload and install any of the drivers or other infoamtion that may be required.
Good Luck
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+3+Series+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+DG33FB
Sep 01, 2011 | Intel BOXDG33FBC Single Pack Uatx G33 Exp...
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I want to know where the connection points are on the motherboard for the front mic and audio jacks. I have a epox ep-5pdaj motherboard. Will you send me a diagram please.
close to the back panel of the mainboard, below the back i/o connectors and 3.5mm audio jacks.
You need to remove the two jumpers from the pins, this is where you connect the front panel audio connector, if your case has each wire separate. then please look at this webpage http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm look at the part "For AC97 Front Panel Audio" PIN 1 should read MIC. If not, then scroll down, you are reading the wrong part of the page.
Aug 07, 2010 | EPoX EP-5PDAJ Motherboard
Hello my mother board is intel D102GGC2.my front audio ports are nt working,
check the jumper behind rear audio panel,. clean it and check the cable connection to the front panel
May 10, 2009 | Intel D102GGC2 Motherboard
How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
Jan 28, 2009 | Zerus Intel Desktop Board D815EEA...
Intel D865GBF Motherboard Logo
1,581 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
