Question about Teledyne Laars Pool & Spa
Pool heater won't stay lit
Pilot will light. will run for 10 min or up to an hour & shuts off. pilot stays lit. pilot generator putting out about 500 mv w/pilot lit. when it runs it may go down to about 300 mv. Need to wait about 3 hours before it will relight the burners. Pilot never goes out. I have jumpered past the switches, (fusible link, high limit switches, pressure switch, fireman switch & on/off switch). Still don't hear the click of the switch in the gas valve. Also I must start from scratch,shut the gas valve off, relight the pilot & turn the gas valve to on before I can get the burner to start again. tested potentiometer w/ohm meter when working & not, ok. I have a sealed circuit board that I don't know how to test & not sure how I can test the gas valve. These are pricey items to replace & be wrong. No local service available, an out of town service call or the wrong repair would put me at almost the cost of a new heater. Any help would be much appreciated. thanks.
  • mykewrench Jun 04, 2009
    problem solved. circuit board had the wrong resistance. fabricate as needed, works great.
    Top Expert:
  • Teledyne Laars Master
  • 4,292 Answers
Check gas pressure might be running out of pressure gas meter might be too small and heater could be overheating
Posted on Mar 19, 2016
  • 139 Answers
SOURCE: hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Posted on Jun 19, 2009
  • 139 Answers
SOURCE: pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Posted on Aug 11, 2009
SOURCE: My Jandy LT 400k heater shuts off when the fan
heater comes on for about 2 minutes then service light comes on and so does the ags light
Posted on Jan 27, 2010
  • 990 Answers
SOURCE: Model LG Lite 2 pilot is lit but the burners will not light
If this is a standing pilot you will want to check your voltage out put from the pilot. For this you will need a milivolt meter. The pilot should supply 500-700mv (1/2-3/4v) It only takes 200mv to open the pilot valve but needs another 300+ to open the main half of the gas valve. This would be the first thing I would check. If this is the problem you will need to replace the pilot assembly. If your getting the power you need from the pilot then it is probally your gas valve itself. Good luck.
Posted on Apr 25, 2010
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
Why won't the pilot light stay lit?
You have a "pilot generator" that sits in the flame of the pilot light. This generates a low voltage output from the flame of the pilot light. This voltage goes to the gas valve and tells the valve that the pilot is lit and to keep the pilot gas line open.
In almost all cases replacing the pilot generator will resolve the issue . They run about $60-$75.
Other causes may be the gas valve itself or a short in the safety loop, in either case should be looked at by a pool tech.
Jul 10, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pilot light on Dyna Glo gas heater won't stay lit
Cleaned pilot light area with an air compressor. Problem solved!
Mar 02, 2009 | Dyna Glo "" Natural Gas Heater Mn200tba
Pool & Spa Logo
426 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
