The top rack will not stay in, especially when full. It rolls out about half way. Worked great until...
(More)(More)
The top rack will not stay in, especially when full. It rolls out about half way. Worked great until about a year ago.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
Help please. I have replaced the plasic sump body which came with a new pressure switch and hose. I...
(More)(More)
Help please. I have replaced the plasic sump body which came with a new pressure switch and hose. I have also replaced the water inlet valve and relay. When I turn the machine on it appears to default to the middle of a program and it is necessary to manually fill the unit with water which pumps out as soon as the power is turned on. If I wait a short while,it commences it's next operation but does not pump sufficient water to move the spray arms. I have taken the spray arms off and turned the machine on and while the water bubbles out, it does not seem to be a very strong flowand is certainly not sufficient to get up to the top spray arm. There are no signs of leaks under the machine, the motor is working well, the drain pump operates and the heat elements are doing their job. I have noted that no water appears to be entering the thin plastic tank on the side of the unit which is connected by a black hose to the NEW water inlet valve.. It might be recalled I was getting an F2 message to tell me the unit was flooding. Since replacing the parts referred to , there have been no error codes but obviously if I am not getting sufficient water through, I will not get a flooding message. I have ensured that all hoses are clear of blockages. Please let me know if additional info isrequired. Thank You. Alan.
Posted. Thank You!
The screen at the bottom of my asko dishwasher is full of solid scum. I can not scrape it off. How...
(More)(More)
The screen at the bottom of my asko dishwasher is full of solid scum. I can not scrape it off. How do I clean this, and why has it collected there?
Posted. Thank You!
Power up..Lights flashing,,,Sounds like starting suction but just keeps going, wash cycle never...
(More)(More)
Power up..Lights flashing,,,Sounds like starting suction but just keeps going, wash cycle never starts. Continues with door open or closed. Water is drained automatically. Sound and lights start right when powered on. Almost like it is stuck in cycle.
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
