Question about Everex StepNote VA4103M Notebook
Earphone jack not working, no sound
My earphone jack has no sound, I have a Everex Stepnote va4300m
Earphone jack doesn't seem to work
tried to hooked up with other earphone jack first, if still doesn't work check the earphone jack of the tv which may have loose contact joint in the board.
Oct 14, 2012 | ViewSonic Televison & Video
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
I have no sound driver for my stepnote va4300m
You can down load the driver here:
http://www.everex.com.tw/us/
By selecting the model and type.
Or here: http://driverscollection.com/?H=StepNote VA4300M&By=Everex&SS=Windows XP&dpage=2
Mar 09, 2011 | Everex StepNote VA4300M Notebook PC
Everex stepnote restore factory settings
To restore your laptop to factory settings read the information from this link.
Dec 20, 2010 | Everex StepNote VA4300M Notebook PC
My stepnote battery is no good i need to replace. how much it costs
Hi
All you need to do is to go online and check it out from online stores or you could call the customer service care of your product.
THANK YOU
Jul 28, 2010 | Everex StepNote VA4300M Notebook PC
I have a everex laptop and its running vista premuim...the fan comes on and it seems to load but nothing shows on the screen any suggestions on how to fix this problem
Depending on your laptop some have a small platic pin that stick up just in front of the screen, if this pin is not coming up your screen will stay off.
Mar 25, 2010 | Everex StepNote VA4300M Notebook PC
Need the power jack for the Everex Everex StepNote
you may want to make sure it is not the power cord first, i thought mine was the power cord, I plugged it up to a different laptop and it worked. so it is something in the laptop..
Nov 03, 2009 | Everex StepNote NC1502 Notebook
I have an Everex StepNote VA4300M Model# VA250W I am trying to find out everything i can about the motherboard but i cant find anything in the BIOS. I ran Belarc Advisor software and this is the info i...
The everex websites seem to be down or not working. The first thing you need to know is you model number. www.everex.com/support
The webpage at http://www.everex.com/support/lm7we/lm7we-support.htm might be temporarily down or it may have moved permanently to a new web address.Have questions regarding your Everex product? Contact our 24 Hour Technical SupportCenter (Toll-Free) at 866.850.8835, email techsupport@everex.com, ...
Dec 31, 2008 | Computers & Internet
Everex StepNote VA4103M Notebook Logo
99 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
