Question about Konica Minolta PagePro 1350W Laser Printer
Streaks on printed page full length even after installing new cartridge
Printer puts streaks on full length of each page printed even after installing new cartridge What piece of glass? I don't see it. My streak is about 2 1/2 inches from left side of the print job.
  • Anonymous Mar 21, 2014
    streaks after I put in new cartridges
  • 71 Answers
Check the glass (the one the paper rests on). The underside of the glass that is. This is what the light 'sees', so, it will print this!
Posted on Jun 03, 2009
I have an HP Laserjet 4, quite old, and it has developed a very prominent streak almost straight down the middle of the page. Staples told me to clean the drum, but my manual doesn't even seem to mention...
Put paper in the manual feed tray. That's the pull down door in the front.
Print something. As the page gets fed 3/4 of the way into the printer, open the top cover. Pull out the toner. Look down at the paper. If you see the prominent streak, you probably have a bad toner cartridge. If the streak is not there, check the fuser. One of the rollers is bad.
While you have the toner in your hand, you should see a flap that is the entire length of the cartridge.
Put you thumb on the flap and pull it down. You will now be looking at the drum.
If you see the prominent streak, that's your problem. See if you can clean it with a soft lint free dry cloth. If the streak comes back, the rubber cleaning blade is probably bad. Replace the toner cartridge.
Feb 07, 2011 | HP LaserJet 4 plus Printer
i took out my drum and cleaned it with alcohol and then wiped down the inside of the printer anywhere the drum touches with a towel soaked with alcohol and the did about 40 prints and it fixed my pagepro (with each of these 40 prints the the quality got better)
May 15, 2009 | Konica Minolta PagePro 1350W Laser Printer
Right Side Printer Streaks full length of page
Hello sir; Make a demo page print out if still have same line coming out, replace the cartridge.
May 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Vertical streaks on printed photos on HP2710 all in one
New cartridges often need a few prints before acting good. Try to clean the heads of the printer also. If the problem consists maybe you need new cartridges.
Jan 19, 2009 | HP Office Equipment & Supplies
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Hey m8
  • Buxie, first off you have voided your warrenty, secondly
  • If marks repeatedly appear on the printed side of the
    page at even intervals:
    • Clean the inside of the printer. See “Cleaning the
    Inside of the Printer” on page 5.7. After cleaning
    the inside of the printer, if you still have the same
    problems, install a new toner cartridge of the
    problem color. See “Replacing Toner Cartridges” on
    page 5.3.
    • Parts of the printer may have toner on them. If the
    defects occur on the back of the page, the problem
    will likely correct itself after a few more pages.
    • The fusing assembly may be damaged. Contact a
    service representative.
  • If horizontally aligned color or black streaks or
    smears appear:
    • A toner cartridge may be installed improperly.
    Remove the toner cartridge and reinsert.
    • A toner cartridge may be defective. Install a new
    toner cartridge.
    • If the problem persists, the printer may require
    repair. Contact a service representative.
  • SXPRESS- It is normal to have to replace it after that because the starter cartridges are rated for 1500 pages but that is at only 5% page coverage and most people print alot higher coverage than that, and the replacements cover 2000 pages again @ 5% page Coverage
May 20, 2008 | Samsung CLP 300 Laser Printer
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Minolta 2300DL Printer - black streaks
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Without actually seeing a print sample or the machine, my bet would be on the black print cartridge. Even though it reads a an acceptable level of toner, the cartridge itself sounds like it has developed a proble. 1. It's the most obvious 2. It't the cheapest place to start. If it does not correct the problem, you can still use it later. 3. It's the problem in about 80% of these types of cases. 4. I know it should be fine, but if things didn't go wrong, I wouldn't have a job! Let me know. If not we'll investigate further. Ed
Konica Minolta PagePro 1350W Laser Printer Logo
289 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
