Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Wireless works for sometime, afterwards it stops.. the only way the wireless works again is to do a cold reboot/reset by turning off and on.. It is getting more frequent and annoying.. is there anything i can do to stop this problem. I have a D-Link wireless router.. I have the same problem over two routers as I took one back to Staples and got a replacement which does the same thing. The Wi-Fi transmitter stays on for a day or two and then goes off and requires a power off/on to get it going again. Sure hope someone comes up with a solution.
  • 256 Answers
The proglem is an electronic component inside is heating up and failing. Today's electronic components are so small, surface mounted, there is just not the mass to disipate the heat. You can try and open the case, feel for the hot part(s) and attach small pieces of aluminum to them for more heat sinking. MAKE SURE NOT TO SHORT ANYTHING OUT!
On my D-Link, two large integrated circuits were overheating. I used crazy glue to attach square "U" shaped alluminum heat sinks to them. The bottom of the "U" was no larger than the top of the IC's. That has helped a lot, but they still quit on me so I let them cool and then I continue computing.
Posted on Jun 03, 2009
M50vc recover wireless
If the problem is with the computer, in the Tray Notification Area, right click on wireless icon and open Network Sharing Center, click on Change Adapter Settings, Is the wireless adapter enabled? In Device Manager, Network Adapters, Is the wireless enabled? Reboot the computer and the wireless access point by removing power and battery and plug in wireless, let it run the selftest, plug in computer and boot normally. You can always Reset the wireless access point to default settings
Nov 30, 2012 | ASUS M50VC-AP012C Notebook
My US Robotics USR5461 Wireless MaxG router needs to be rebooted quite often (sometimes once or twice a day) to get internet access back. The status page says it's connected to the internet but I can't...
Considering the frequency you have to reboot the router to get it to work may indicate a glitch with the WAN gateway.
I recommend fully resetting the router and setting the wireless network up again.
You should be able to reset the router using a pin and sticking it in the pin hole on the back of the router near the power source.
Thanks,
Pat
Jan 03, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
I have mac and its not working
Should work, macs like networking. Reset router with button on back (in manual). then try again. you will have to set up the encryption afterward, to stop the neighbors using your internet. LOL
Sep 28, 2009 | NetGear WGR614 Wireless Router
Wireless stopped working. If correctly plugged
Have you tried a hard reset, then setting up the wireless again?
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 10, 2009 | Computers & Internet
Wireless Internet stopped working. Can't reconnect.
If restarting the router and restarting computer did not work (unplug both power cables), then you need to log into the router and check network settings.
To log into router type the router IP on internet explore bar, then enter user id and password.
You find details on how to do this, IP and passwords listed on the owner manual.
If wireless security settings on router are fine, then you can reset router to factory default using the pinhole switch. You will need to enter all your broadband settings to have the router working afterward.
Apr 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless router not connecting to internet
Unhook all wires except for the power cable. Press and hold the little reset button on the back of the router for 30 seconds ( I know, most sites say 5 seconds is enough...)
After releasing the button the router should reboot itself. Sometimes after the reboot you have to press the reset button again for just a second and release it. The wireless should reset itself at this point, but this will also reset all of the router settings. You will have to log into the interface and reset your security and other settings. The user id & password should reset to admin & motorola, unless you have loaded aftermarket firmware.
Apr 09, 2008 | Arris Wireless G Broadband Router (wr850g)
Microsoft Wireless Desktop 4000 receiver quit working
They need to be re-synced. Sometimes the wireless signal from the keyboard/mouse is broken and the receiver cannot find it again. A quick re-sync always fixed the problem for me.
Aug 07, 2007 | Microsoft Wireless Laser Desktop 4000...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
209 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
