Question about Panasonic CW-1006FU Air Conditioner
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then holding the middle "up" button till it beeped and a error code came up,as per manual, however there was no "beeping" sound nor a code. any ideas? Same thingh here. I have a CS-E12EKU that every other month the timer light goes on. Faulty board?
  • Anonymous Mar 13, 2014
    Model is a CS E15 FKR wall unit. The timer light just flashes. The air conditioner just wont work, and none of the controls on the remote will turn it on. I tried holding down the reset button, but it made no difference
What means mistake H 26?Does anybody know?
Posted on Aug 10, 2012
  • tzvety_86
    tzvety_86 Aug 10, 2012
    what means mistake H 26?Does anybody know?
Hi, I had exactly the same problem.  You need to keep pressing the middle "up" button until you reach the number of the error and then it will beep.
My error is number 15, I have to contact the repairer to see what it means. Hope this helps.
Posted on Aug 26, 2009
    President:
  • 1,902 Answers
This is a sign of a bad board. They are cheap and easy to replace. They will need to be replaced or you will continue to have this problem for as long as you own the unit
Posted on Jun 03, 2009
Panasonic CS-E24FKR Airconditioner keeps turning off. Error code 15 H
Is the air-conditioner plugged into an extention cord or directly into the wall outlet???
Aug 20, 2016 | Panasonic Heating & Cooling
Timer blinking.outdoor unit does not functioning. what was the error?
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Apr 28, 2015 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Indicator light keep blinking for SHARP ECO INVERTER
The unit has popped up an error code. There is something wrong with the unit. What is the model number? 25325502-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
Dec 16, 2014 | Kenmore Ac Airconditioner Remote Control...
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
How to set hold recall time for a longer period
Pana's hold recall is always in system program 200.
Apr 06, 2009 | Panasonic KX-T7731 Corded Phone
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Air con timer flashes cs/cu-e24fkr
likely it is low on battery juice . open it and replace
Jun 04, 2008 | Panasonic Heating & Cooling
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Jun 03, 2008 | Heating & Cooling
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Panasonic CW-1006FU Air Conditioner Logo
1,954 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
