Question about Iomega 160GB Ego HD USB 2.0/FW Red 160 GB Hard Drive
Starting to lose power...now needs to use dc adaptor
I have an iomega external hard drive (Model RPHD-U). It used to work awesome just by plugging the two usb cords into a computer. I now have to buy and use a dc adapter for to get it moving. Why? It's less then a year old. Any ideas on how to make it work just with the two usb plugs? Thanks
  • xbeachyxkeen Jun 04, 2009
    Thank you for helping me out.
    I've tried it on 3 different computers.
    1. My laptop... it seems to work fine without attaching the dc adaptor.
    2. My work computer... it used to work fine without the dc adaptor. However, I now need to hook up the dc.
    3. School computer. It worked at first but now need to hook up the dc adaptor unless I plug it into the back usb slots and slightly shake the iomega a little.
  • Chris
    Chris May 11, 2010
    Are you using it on a laptop or desktop?
    if it's a laptop, is it plugged into power or running from battery when it has trouble?
    Let me know and we'll work through this.
    Chris
No I Have The Same Prob M8 Thay Need Power
Posted on Jun 06, 2009
How to unprotected
It may be you're trying to move files under the wrong credentials
. In which case you'll need to log in as administrator before you'll be able to copy.
Apr 13, 2016 | Iomega Ego Rphd u 250gb Usb 2.0 2.5...
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
Iomega external hard drive power is not coming on.
Samething happen to my Iomega screenplay media drive.
My problem was a AC/DC power adaptor that was in short-circuit.I bought one off EBAY and all good again.
Search for 12v dc 2.0 amp power adaptor.Has to be 2.0 amp ,as anything less ,will not work and most available are only 300 ma.
Good luck
Feb 19, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have a Iomega 500G portable hard drive RPHD-U, when I plug the USB 2.0 in I hear a clicking noise on my HP computer. The portable haed does not show up in the my computer devices. This device use to be...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Jan 08, 2011 | Iomega eGo Portable Hard drive 500 GB ...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Aug 08, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
I have an Iomega external hard drive. P/N is 31641400. model is MDHD320-U. I have been unable to locate any DC12V adapter to work on my external hard drive. Could you please assist me in finding one that...
please check the power rating and the amperage rating
you will get it as 500ma or 1amp or 1.5amp.
and as 12 volts.
so a adapter with specifications of 12v DC. 1.5 AMPS WILL WORK.
IF 1.5 AMPS IS NOT AVAILABLE USE 1 AMP THIS SHOULD ALSO WORK
IF YOU FAIL SEND THE DRIVE TO ME....
NUMBER +0-9-3-2-1-1-0-1-7-1-7
Apr 18, 2008 | Iomega 33089 250 GB Hard Drive
Iomega 160GB Ego HD USB 2.0/FW Red 160 GB Hard Drive Logo
1,033 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
