Question about Mtd Troy-Bilt Bronco OHV Tiller
Mtd rototiller runs fine untill load is put on it then dies
As soon as we put it into the dirt it starts to squeak then slowly dies unless you take your hand off the throttle
2 Suggested Answers
  • 221 Answers
SOURCE: have a rototiller it moves ok but the tines do not
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Posted on May 06, 2010
Troy Bilt edger dies as soon as its under a load--like edging my driveway.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Nov 23, 2011 | Mtd Garden
MTD Briggs and Straton 22" Mower Wont Start Brand
You probably have dirt in the carburetor. Or, you may have water in the fuel. As long as you have spark, then there is nothing else that it could be. Unless you have taken it apart already; have you done this?
Jim
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
When I lower my yard bug mower deck, the engine dies. It runs fine until I lower the deck. Help!!
when the deck( blade) is engaged it puts a load on the engine. that tells me theire is some type of bolckage to the belt/force of the movement and is keeping the engine of moving freely. check to see if there is any blockage of the blades, or the belt is loose or off track.
Jun 13, 2011 | Mtd Garden
How do you start the Huskee Rototiller 190CC? My
Yes, the engine is identical to the ones used on several lawnmowers and the safety bar must be held in against the handle to enable it to start. Releasing it while running will kill the engine.
Apr 11, 2011 | Mtd Products Yard Machines 158CC Tiller
1981 Honda CT110 trail. Runs perfect for about 5 miles then dies. Starts a couple times each time slowly idling down until it dies then it will not start again for until it sits for an hour or so. I...
It sounds like you still have dirt floating around. What did you coat the tank with? I used POR-15 with great results. Install a gas filter that you can see through and see if you are still getting dirt from the tank. Check the new carb for dirt. It sounds like something is somewhat plugged which allows gas to slowly fill your carb after it sits. But this clog is what causes your bike to stop after 5 miles. Does your tank have a shutoff valve? Run a line from the valve to a jar and see how well the gas flows. The shutoff valves usually have a screen....check it for dirt.
Nov 26, 2010 | 1982 Honda VT 250 F
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
88 cherokee 4 litre loading up with gas stalling
it almost sounds like the timing is off causing it to load up on fuel.
Feb 27, 2009 | 1991 Jeep Cherokee Briarwood
Mtd Troy-Bilt Bronco OHV Tiller  Logo
310 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
