Question about ASUS Motherboard Striker II Extreme (90-MIB2T0-G0EAY00Z)
Automatic restart, temperature fine (using sunbeam core contact freeezer), reinstall os doesn't fix the problem (using vista ultimate x64 better but restart still occur)
Always reboot automatically
  • Sudeep Chatterjee
    Sudeep Chatterjee May 11, 2010
    what OS are you using & any other hardware that you have got in your PC? Model & Make?
    Sniper:
  • 51 Answers
Remove all expansion cards other than video and see if that has any effect. Swap out the RAM with another module, if available, or remove one module at a time if you have more than one installed.
Posted on Jun 23, 2009
Tip
Transform your windows xp to windows 7
Features
Seven Transformation Pack will replace many of the resources in Windows Vista/XP/Server 2003. It can change such things as:
Boot screen
Welcome Screen / Logon Screen
New msstyles files (visual styles)
New desktop and file icons
New toolbar icons
Progress Dialogs
Sounds scheme
System Tray icons
New Wallpapers
Some Windows 7's popular features
And much more
Changes in Version 5.0
-Added automate User Account Control deactivation upon checking
-Added changing desktop wallpaper during transformation
-Added completed set of Windows 7 wallpapers
-Added Gavatx's Rainbar in Vista compatibilities exclusion list as there's already Windows Sidebar in Vista
-Fixed bugs that some options are not saved in registry during installation
-Fixed currupt system sounds scheme in Windows Vista after uninstallation
-Fixed logon screen system files modification to not change system font in non-English MUI (Requires uninstall for older version)
-Fixed setup files detection glitches in Windows XP/2003 x64 Edition
-Fixed system files modification critical error for integration with Windows XP/2003 x64 Editions
-Fixed system files modification compatibilities with non-English edition OS
-Fixed Welcome Center not running on startup after installation on x64 operating system
-Fixed x64 system files modification incompatibilities for some systems
-Improved transformation process for faster and better performance (This involves a lot of work in various places and they're all technical stuff)
-Optimized Deferred Launcher's startup sequence and delay time for better resource utilization
-Removed minimum hardware requirements for 3rd-party applications but still keep recommended specifications in list
-Shortened installation sequence UI for smoother process
-Updated 3rd-party applications hardware requirements specifications
-Updated screensaver to Windows 7 logo
-Updated TrueTransparency
'-Core program to version 1.4
'-Optimized blurring interval for better system performance
'-Rebuilt SevenStyle skins based on Seven structure with real reflections
'-x64 application support
-Updated ViGlance to version SE2 build 1276
'-Added Drag shortcut support
'-Added Hyprid Jumplist support
'-Added Shift+Left click opens new instance
'-Fixed 64-bit application compatibilities
'-Fixed multi-monitor compatibilities
'-Fixed UI and code refinements
'-Optimized timer interval and program configuration
'-Updated default skin
-Updated ViStart to version 2.0 build 3738
'-Added blur support (experimental)
'-Added run functionality in searchbox
'-Optimized programs discovery routine with better program support
'-Optimized UI rendering for better performance
-Updated Welcome Center
'-Added back button in ui navigation control
'-Added system files repair list in repair page and Repair alert with red text
'-Fixed icon and text UI placement
'-Removed using system files from backup source in uninstallation
'-Reworked Removal UI with installed components verification to ensure safety of uninstallation
'-Updated backup files status indicator to available/not available (no need for overwritten check)
'-Windows 7's additional user pictures and wallpapers will no longer be removed (few MBs being too insignificant for TB storage)
-Updated UXTheme patching engine to deepxw's universal theme patcher
Screenshots---
Download it from here---
http://hifkool.blogspot.com/2011/03/new-transform-your-windows-xp-to.html
It works perfectly and tested by me...
For more softwares and antiviruses go here
on Mar 28, 2011 | Computers & Internet
No sound in Windows 7
Uninstall all the audio drivers and restart the computer. Make sure the audio jack is in the Green audio port.
Let the operating system re-detect the audio and install the drivers for it itself. When its done see if you have any sound.
Post back if this does not work.
Good luck.
Nov 17, 2009 | Microsoft Computers & Internet
A vista OS is failing to detect lexmark 8300 via USB port When i plug a flash or another usb device on the same port it plays i tried to reinstall the drivers but they cant work. what could be the problem...
ok.....
  • click the start button.
  • type "services.msc" in the run bar.
  • Allow it through UAC.
  • now search for an entry called "print spooler
  • double click it
  • in the startup type type select "automatic".
  • restart system
  • this should fix ur problem.
Jan 13, 2009 | Microsoft Windows Vista Ultimate Edition
Vista goes blue and restart after unnistalling intel turbo memory
I'm afraid that the only way is to reinstal Vista. If you recive a message that says that Vista arent capeble to repait it self ther is no other way. I Guess that the instalation of the driver for Intel Turbo Memory messed up Vista pretty good and uninstal it dosent help. You will always have bad file system on Vista. Better then to star from the begining with a fresh reinstal.
Good luck
Nov 21, 2008 | Computers & Internet
Nero 8.0 and vista
Reinstall the nero 8 and restart the system. If problem persists then it is better to change the OS to windows XP SP2.
Oct 28, 2008 | Microsoft Windows Vista Ultimate Edition
Windows vista
Appreciate the direct "Ask me" again and likewise the previous ratings.
To my knowledge, Vista x64 is just an x32 with 64 bit addressing. Some have reported that 64 bit on a Core 2 Duo isn't a very good idea with the extra speed gain of x64 over x86 being marginal for now. Offhand, you might be better off still with X32 at least for the time being.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Microsoft Windows Vista Ultimate Edition
Conversion of 32 bit vista into 64 bit
You have to buy windows vista x64 bit version, or if it is included install x64 bit when the screen comes up and says:
Install x86
Install x64 <-- Choose this one
Jul 21, 2008 | Microsoft Windows Vista Ultimate Edition
Laptop keyboard not working in compaqv3000.
i reinstall all the driver of my vista laptop drive especially bios and restart my computer and this solve my problem.
Feb 11, 2008 | Compaq 310640-001 Keyboard for Presario...
ASUS Motherboard Striker II Extreme (90-MIB2T0-G0EAY00Z) Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
