Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction in upright position
My Dyson has good suction in the upright position, but when I tilt the handle to vacuum, it looses all suction.
  • 5 more comments
  • Anonymous Dec 05, 2007
    When I remove my hose to use it there seems to be hardly any suction. Have cleaned filters but seems to be blowing out under the clear cycinder where the round filter is.
  • Danny Templeton Dec 14, 2008
    I have a Dyson DC07, and I have to manually push down on the Automatic Carpet Height Adjustment (ACHA).  I have no suction on the vacuum.  It drives me nuts to have to keep doing this function to vacuum.   When I push the vacuum out in front of me, it looses suction, and I have to manually push the ACHA again and again.
    Any help?
    Dan, they i'm trying to vacuum man!
  • Anonymous Mar 16, 2014
    hard to push the vacuum, no suction
    My Dyson does't lock in the upright position
  • Anonymous Mar 21, 2014
    Shark vacuum looses suction
  • Anonymous Mar 28, 2014
    Suction through upright, pull out hose and suction gone will then sound very noisy. Have che key down hose and cannot find blockage
  • Anonymous Apr 01, 2014
    Suction is too hard. How do you adjust the suction? The suction is too hard
    Problem Solver:
  • 7 Answers
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap. Dyson...their support is great!
Posted on Nov 07, 2007
Dyson DC 25 power shuts off in upright position
To clarify, do you mean the suction and brush motion shut off in the upright position, or that the entire unit shuts off?
If the latter, most Dyson uprights shut off the brush unit in the full upright position and shunt the suction into the handle for use with the accessories. There is also an on/off for the brush, next to the main power button for the DC25. If it's off ( or stuck that way), no brush motion. The manual also notes, 'for use, turn on power and click the foot pedal in back to recline the unit.' (Link to manual here: See Page 8). The
'High Reach Cleaning' section also notes that the brush bar won't rotate when the vacuum is in the full upright position.
If you are completely losing power, the manual notes that the unit will shut off if the bar is jammed, or if there is a significant line blockage that makes the motor overheat. If this is happening, check the accessory line in the handle for blockage.
Good Luck :-)
Jul 11, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I restore suction?
Cheap plastic parts. trade it in on a good vacuum like panasonic
Dec 31, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson DC 28 works great, until I remove the bag to empty it. I reattach it, clicking it carefully in place, but then I release the "tilt" thing to vacuum carpet, and NO SUCTION! I have to keep taking...
On the back of the Hoover is a couple of parts you can remove, one is a u bend which will trap heavier parts which resist the suction so get stuck in the bottom of this, and the other part is usually on the right at the bottom which is an acces point to the very art which you hear click. In the upright position it directs the vacuum suction up the extendable pipe, but when you pull the handle back, it should gently glide from one direction over to direct vacuum suction to the bottom plate. It's tha part which is getting stuck in the handle sucking direction. I'd check to see if it is physically damaged in any way or if something is tapped in it like a coin or something. Good luck
Nov 25, 2013 | Dyson DC28 Animal Airmuscle Vacuum 00247
When the dyson is turned on the suction goes to the wand when you tip the beater down you do not have as much suction you cant pick up lint.
The Dyson system is designed to operate the hose with the handle in the upright position. When the head is tipped down (floor vacuum position) it closes the opening to the hose/wand
Nov 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at
Kind regards
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
Oct 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I just purchased a DC07 Dyson vacuum cleaner. It is not vacumming my floor - I have hardly any suction at all. Do I need to activate something in order to initiate the suction?
With vac upright suction is sent to the hose ie top of vac handle when handle is tilted down to the user vacuum position it should send the power suction to the floor also make sure collection bin it in securely that make be the problem
Sep 08, 2008 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
1,333 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
