Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Gargling noise When you open and close the freezer (Amana abb2524dew) you hear a gargling noise. It still works but if there is a symptom I fear problems in the near future.
    Problem Solver:
  • 9 Answers
1# if there is any shortage of gas this type of noise you can hear,but this happens only if you feel there is less or insuffient cooling .
2# check water drain point,may be there is air trap and making noise.
Posted on Jun 03, 2009
On my Amana ABB2524DEW frig the ice maker is not working. It made a few ice cubes and then stopped. We are renters and the frig was already installed when we moved in. Ideas?
Hello, Thank You for using FixYa. I will be helping you today. I would check the fill tube comming thru the back wall to see if it froze up. You can pull it out from the back. Also make sure the water is on all the way. There may be a stuck ice cube. Also the arm should be in the down position. Hope this helps.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Amana ABB2524DE Bottom Freezer...
Fridge and bottom freezer not cooling. Light on when door opened. Is there a reset switch/button? It is an Amana
There is not a reset switch/button. Do you hear any noise at all, fans or clicking noises?
Jan 11, 2011 | Amana ABB1927DE Bottom Freezer...
Loud humming noise (vibration) from freezer section when running. Amana refrigerator (freezer on bottom) model BC21VW
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
Mar 24, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
Amana ABB2224DEW bottom freezer defrost problem
You have a defrost problem. You will need to replace your defrost system. Before you put the parts on, you need to completely thaw out your unit. You can do this by leaving it open all day or night or by placing a fan close to it with the door open. We have parts, so please give us a call and we'll be sure to ge the right parts out to you right away. We look forward to hearing back from you.
Sep 16, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer Door Handle Broken on Amana ABB2524DEW
if your in your first year of having this refrigerator then the part is covered. with your extended warr. the parts that are basic function parts are the only covered. not cosmetic. keep calling the customer service. don't give up.
Jun 24, 2009 | Amana ARB8057CSL Bottom Freezer...
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Jan 21, 2009 | Amana Refrigerators
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
267 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
