Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Remote Contol will not work, though batteries are new and red light is blinking
Hello, Remote Control will not work. I don't know the code or how to input the code into the remote control correctly. JUST GOT THE TV AND PUT BATTERIES IN THE REMOTE AND IT DIDN'T WORK. GOT MORE NEW BATTERIES AND THAT DOESN'T WORK. GOT A UNIVERSAL REMOTE AND THAT DOESN'T WORK EITHER. NOW WHAT DO I DO???
  • 89 Answers
If it is a universal remote just look up your t.v. in the instuction book that came with the remote,and follow the instructions in the book on how to put in the code for your t.v.
Posted on Jun 03, 2009
Remote not working
I have rebooted several times during the reinstallation of the software. I also tried different USB, but no luck! Could it be something with the USB driver anyway? The system says the drivers are ok though.. Does anybody know the life expectancy of the batteries to this remote? I don't think it is the batteries though, because the red light on the remote is bright.
Nov 12, 2012 | Sony Nsgmr1 Remote Control
I bought a used samsung t.v. and the remote don't work. its got new batteries but don't work it might be a samsung universal remote do i need to but my t.v. code in it. how do i do it and what is...
Hello
Three digit universal remote codes to check with Samsung tV are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four digit codes are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 26, 2011 | Samsung TV Remote Control
I HAVE A ONE FOR ALL URC 7040 UNIVERASAL REMOTE CONTOL. I CANNOT FIND A CODE FOR A DVD PLAYER BRAND OLIN. CAN YOU HELP
The codes are, 0037,0218, Have fresh batteries,press TV button, press and hold down the MAGIC button,red light blinks twice, enter one of the four digit codes, press POWER.....hope this was helpful...
Apr 20, 2010 | One For All URC-3021 Remote Control
CODE FOR TV SONY
If the code you are looking for is for a Phillips universal remote this may help you. My codes are for a fairly new Phillips universal though... Just hold the code-search or setup button found near the top of the remote and hold it until a red light turns on. then enter in the codes i'm going to list until one of them works. If you enter in the code and the red light turns of it should work. if the light blinks then it doesn't work. Make sure you try all of the codes before you give up.
0414 0902 0801 0708 0639 0816
Apr 10, 2010 | RCA RCU403 Remote Control
How do i get it connected to the tv? and how do u use codes i dont know how to use the codes
To get your Innovage Jumbo Remote Control connected to your TV you need to program it with control codes specific to the brand of your TV. If you know the brand of TV you have you can look up the control codes for that brand in a chart. If you don't know the brand, or if the codes in the chart do not work on your TV, you can perform the auto-search function of your remote to find the codes that work.
To search for the control codes that will work on your TV, follow these steps:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 08, 2009 | Innovage Jumbo Remote Control
Hi I carn't set up my total contol remote for my tv can you help
Hi fishbones675,
Not a problem - here's how to do it:
1) Turn on your TV.
2) On your Total Control Remote, press and release the TV button.
3) Press and *hold* the SET button (the red light will blink once - keep holding it - it will then blink twice - release the button).
4) Enter the four digit code for your TV (the red light will hen blink twice).
5) Press POWER - the TV should turn off. This will mean that the remote has successfully been programmed.
If you don't know the code for your TV, refer to the list of codes in the user manual, available at the following web address:
http://www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
If your TV brand is not on the list, or if the codes for your brand don't work (which I've only seen happen once), then try the CODE SEARCH feature:
1) Press TV.
2) Press and hold SET (as above)
3) Press 9-9-1.
4) Alternate between pressing the TV and POWER buttons. When your TV turns off, that means the remote has found a code that will operate your TV.
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Televison & Video
Philips universal remote control SRU 1060 code for toshiba tv
Try with this.
Turn on the tv.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the Code search button.
Press and release the desired mode button ( tv,vcr,etc. ) The red indicator blinks,then stays lit.
Enter the 4 digit code from the code tables.0517,0419,0512,0613,0719,0112,0506,0111,0618,0627,0437,0041,0094,0802,0313,0715,with one of this codes your tv can operate.
With your device on,press CHANNEL UP .If the device responds,no further programming is required.
Good luck
Oct 09, 2008 | Televison & Video
Jizzz i´m desperate!!!!
jenson 300 series Sony tv codes 497,491,475,459,406 or the code you have
hold the program or setup button untill it blinks. select the tv function and enter the code you have or one i listed above then enter
Or if your remote is this 300c series your code would be 0000
you would press down and release the device"mode key"tv,vcr,ect
the red light will blink once.press and hold down the setup key untill red light blinks twice then release.enter the code the led light will blink once on each digit execpt the last one will blink twice to confirm valid code ****mode 1 is for the tv on this remote.
hope this helps
Mar 18, 2008 | Jensen JER-323 Remote Control
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
158 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
