Question about HP Pavilion ze2000 Notebook
USB none of the usb ports on my ze2000 detect anything i plug into them...i looked to see if they were functional in my control panel and it said they were fine...any tips on fixing USB port/ detection?
  • Anonymous Nov 11, 2007
    I am having the same problem. Only one of my three USB ports is working. Any suggestions?
I had a similar problem, with no help from HP support. A USB hard drive would be recognized, and work, but a Sandisk flash drive and a Fujifilm camera would not. All drivers were uninstalled/reinstalled/updated numerous times. HP finally concluded a hardware problem. However, I noticed an updated BIOS on HP's web site to fix "USB problems" with some equipment. I flashed my BIOS with the new version, and USB now works. Some minor glitches, but acceptable..
Posted on Nov 12, 2007
My usb modem [lemon 3g] does not get detected. when i plug the modem it does not show anything i.e usb icon detected hardware etc. when i clikc on cmy computer also it does not show any connection why is...
First, check for the power source, there should be a light indicator on the panel of the modem, else, power is a problem, check your adapter/power cable. Next, is use USB cable/USB port, try to use other USB cable/USB port. Another option is to check your Control Panel - Device Manager, see if there is a USB Modem currently installed. Remove/delete the device from your Device Manager. Going back to Control Panel, select Add Hardware. If still fails to detect, your Modem is dead.
Good luck.
TedMac
Sep 18, 2010 | Computers & Internet
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
The microphone is not detected
you cn check the connection b going into the properties of your sound card page and go to the section for input check if the mic shows up have you any drivers loaded for the mic... if you go to setting then control panel look for the sound and audio box there is block there for speech check you mic is selected.. you can try connecting via afront panel usb port as well or via you sound card inputs on the back panel
Jul 31, 2009 | Logitech USB Desktop Consumer Microphone
My pc won't detect my printer, my printer is brother dcp 150-c
have you connected the printer's USB port to your CPU? If not, then do so. If after doing it, still your PC don't detect your printer, make sure you have a functional USB port. To check it, try using a USB Flash drive if it works with your PC. If it won't, you might have to "Enable" your USB at your BIOS.
Regards!
Jul 09, 2009 | Office Equipment & Supplies
My Panasonic CF-74 doesn't seem to be detecting anything I am plugging into the USB ports or the COM port.
Some motherboard BIOS's allow you to specify how many USB ports you want enabled
go to your Control Panel, System, Device Manager.
go down to where it says Universal Serial Bus Controllers, click the + sign,
you will see a list of devices, probably something like this
via rev5 usb host controller
usb printing support
usb mass storage controller
usb root hub
usb root hub
right click on the ones that say via or intel or SIS, or ALI, or Standard open host controller, and choose uninstall.
you will be asked if your sure, and you will see some of the USB root hubs disappear.
If you are asked to restart, choose no, and remove the other via/sis/intel/etc open host controller (s) from your system, when they have all been removed restart your computer.
when the computer restarts, it will detect the USB controller and connected devices, reinstall the drivers/software
Jun 24, 2009 | Panasonic Toughbook 74 PC Notebook
Keyboard not functioning at all
The problem may be two things:
1) Its cord is disconnected from the PC unit
2) Your Keyboard drivers are outdated.
If the cord is fine, I recommend that you go to the hardware wizard (Start Menu -> Settings -> Control Panel -> Hardware Wizard) and run a "detect new hardware." This feature should be able to get your keyboard going again - and you should be able to access this feature by using your mouse only.
Aug 06, 2008 | Microsoft Natural Ergonomic 4000
USB
First of all, I recommend you to Uninstall the USB Devices from the Device Manager and reinstall the Chipset Drivers as per the instructions below :
Click on Start and then on Run.
Type devmgmt.msc in the Run Command box and click on OK.
This will open the Device Manager window.
In this, click on the + mark next to Universal Serial Bus Controllers which will display additional USB Entries.
Right click on each of the entry and select Uninstall.
Click on OK if you get any confirmation window. Repeate the same process untill there are no entries left under Universal Serial Bus Controllers in the Device Manager window.
We are done with uninstalling the USB Drivers from the Notebook.
Now, restart the Notebook and close any window which says 'Found new hardware'
Now, download and install the Chipset Driver in your Notebook from the link below :
http://downloadmirror.intel.com/8178/a08/infinst_autol.exe
Save the file in the Notebook and double click to install the Chipset Drivers.
However, if the issue with the USB Ports persists, I recommend you to check again with different devices to confirm if the issue is with the USB Ports of the Notebook itself.
If the Notebook doesnot recognize any of the USB Devices after installing the Chipset Drivers, you may need to get the USB Ports of the Notebook replaced or go with a PCMCIA USB Card.
Hope this helps....
Jul 09, 2008 | HP Pavilion dv4000 Notebook
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
Ext.hdd can't be detected..
When you have the drive connected,go to your control panel,open up Administrative tools,Computer Management,Disk Management.See if drive is there.If it is, right click in drive space ,assign a drive letter.
If not,scan for new hardware.
You could also look at your usb port handler in your device manager.Update your usb controller,usb handler
Jan 18, 2008 | Computers & Internet
Usb ports
Make sure that USB ports are enabled in your PC.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
HP Pavilion ze2000 Notebook Logo
189 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
