Question about Q-Logic QLE4060C-CK Network Adapter
Jetta blowing hot air out of a/c
I have a 2002 volkswagon jetta with a 2.8 v6 engine all of a sudden the ac blows hot air. i recharged the system but still blows hot air, and is now running hot and radiator fans won't come on.
You need fan control mod. left front of car may be under battery when front mounted
Posted on Jun 12, 2009
What would make my ac blow hot air
Most likely your coolant needs to be recharged. /you may have a leak in your system and you should have it checked.
Mar 17, 2015 | 2007 Toyota Avalon
AC blows hot air out the front vents no matter the setting. It is winter so it is not too bad. The back vents blow cool air but not cold.
Getting your system recharged at a dealership would be recommended but only hot air coming through the front could be an hvac problem, make sure that all your vacuum lines that run to your system are not crushed or unplugged, they will be located in the engine bay of your vehicle.
Jan 29, 2013 | 2001 Toyota Sequoia
AC will blow cold air for a few minutes then start blowing hot air, cut the engine and start it again and blow cold air for a few minutes then start blowing hot air again. Just filled up the freon and the...
you have moisture in the system this causes your expancion valve to freeze up an stop working, thats why it works for sort time and when it de-freezes stars working again. you need to do a EVAC & RECHARGE with a good AC service equipment, specially attention to pull vacumm por at least 20minutes so you get all moisture out of the system.
Good luck
Jun 05, 2011 | 2002 Hyundai Santa Fe
Ac blows hot air
If your AC blows hot air, these could be the culprit:
1. Not enough refrigerant for the AC system
2. Busted AC compressor
Sep 04, 2010 | 2002 Saturn L-Series
I have a 2002 Acura RSX that has AC Problem. Blows very cold air, but not all the time. As long as RPM is running at drive speeds, I have cold air. However, at stop lights the air temp goes warm. If I...
your ac compressor is freezing up try not putting it on cold all the way. put thermostat towards the red jus a lil but still on the cold side to see if that helps
Apr 03, 2010 | 2002 Acura RSX
AC blows hot air but AC compressor works
if the compressor works and your freon is charged it may be the blower flapper door....disconnect battery for 10 minutes and then re-connect to reset the electronics that control the flapper
Jan 12, 2010 | 2001 Mercury Sable
Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Sep 03, 2009 | 2002 Dodge Durango
2002 Lincoln LS V6. AC blowing hot air but sometimes it works fine and blows cool. Is it a sensor problem?
its probably the compressor cutoff switch cutting your compressor off at the wrong time and causing your ac to blow hot. that switch is under your hood right on top of the engine easy to get to. I hope that helps you out!
Jul 17, 2009 | 2001 Lincoln LS
2002 New VW Beetle is only blowing hot air out of vents even when set on cool. I was driving and I made a turn at an intersection and all of a sudden the cool vent air turned to hot air like I had the heat...
On the bottom of the air unit is the lever that changes temps. It likes to fall out of place.I propped mine back with a piece of half-inch copper pipe a couple of years ago.Remove glove box then panel on front side of console to access.
Apr 09, 2009 | 2003 Nissan Altima
Q-Logic QLE4060C-CK Network Adapter Logo
456 people viewed this question
Top Q-Logic Computers & Internet Experts
David Payne
David Payne
Are you a Q-Logic Computer and Internet Expert? Answer questions, earn points and help others
