Question about LG Shine KE970 Cellular Phone
LG shine: using my mp3s as ringtones
I just got a LG shine...i can get the music onto my phone...via bluetooth as well as micro SD card...but i cant use them as ringtones. ive used large files as well and small files...files smaller than the ones that come on the phone...but it wont let me use them as ringtones. what am i doing wrong or is it possible? I sent songs from my computer to through bluetooth and I want to set it as a ringtone but the file is to big. How do I solve this?
    Brigadier General:
  • 7,752 Answers
On the shine that is not possible sorry
Posted on Jun 03, 2009
Why the music cant be ringtones too?
There's a couple of reasons why this won't work. One, the MicroSD card is only for storage of music and other data, while your ringtones are stored on the phone itself. Secondly, your phone does not use .mp3 formatted files for ringtones.
You'll need software and a data cable to create ringtones using .mp3s to convert the song (and slice it) to where it can be used as a ringtone, and the data cable will allow you to store it on the phone where it can be accessed as a ringtone.
Susteen (susteen.com) offers datapilot software that can do this, and there are others who will as well.
Jul 21, 2009 | LG RUMOR Cellular Phone
Deleting Default Sounds on LG Shine
On the memory card you have to make folder named MP3 and put there your favorite songs that you want to listen in your MP3 player and they will appear
May 28, 2009 | LG Shine KE970 Cellular Phone
Cant download ringtones to my LG shine phone
you have to have a memory card in your phone for it to show up as an attached device.....otherwise you will need a program that will recognize the device to transfer data to it. i recommend getting a cheap little micro sd card so that you can simply pull up the device from <my computer> and copy the ringtones/mp3s straight to the removable disk.
good luck
Mar 11, 2009 | LG Shine KE970 Cellular Phone
Lg Shine Flip Ringtones
-Make sure the file is appropriate.. 30 seconds or less, mp3 format
-When you add your music to the memory card, it shows up as a song but not as a ringtone right?
The solution is to create a different folder rather than using the “Music” folder the phoneautomatically creates for you. Transfer your music to this new folder you’ve created. The ringtones should show up as long as it fits the requirements
Hope this helps
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Sorry That Files cant be Deleted in ANY WAY -
No Maykalaal Can delete those files -
Those files are Fixed in ROM Drive -
U Cant Modify Files From ROM Drive -
U Can Copy send But Cant Edit or Delete -
Helped:
Jan 27, 2009 | LG Shine KE970 Cellular Phone
How do i get music on my lg shine using a sd card
go to att music and go to music player hit all songs. it will update the library and show the songs from your card, you can play them from here but i don't believe you can use them as ring tones from here.
Jan 08, 2009 | LG Shine KE970 Cellular Phone
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Lg shine - downloading music from my laptop
If you want to put music files from your laptop onto your LG Shine, you can either use a LG USB cable or a Micro SD Card.The Micro SD card will probably need an additional adapter to have it big enough for your Laptop or PC slot. Once the music files are on the Micro SD card, insert the card into your LG Shine and go to My Stuff". Then, select "Audio and ringtones" and select the file on your memory card. Press the "Options" button and select the copy function and paste it into your phone.
Jul 28, 2008 | LG Shine KE970 Cellular Phone
Cant transfer music file to my lg ku990 via usb from pc to phone
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
Jul 27, 2008 | LG KU990 Viewty
Make sure the file is mp3 format, 600 kb or smaller, and 30 seconds or less. You can make your own ringtones at the following sites:
www.cellsea.com
www.makeownringtone.com
www.ventones.com
www.myxertone.com
Once you have your ringtones ready, there are many different steps you can follow depending on what you have available on your phone.
1. If you have internet/text messaging: sites like cellsea and myxertone will provide you with instructions.
2. If you have a usb cable: connect your phone making sure it's in Mass Storage Mode. You can do this by going to settings, connection, usb connection mode, mass storage. Open the folder for your phone on your computer. It should be one of the choices of storage when you go to My Computer. Place your ringtones into the Sounds folder. And voila! It should be in the ringtone menu in your phone.
3. If you have a MicroSD memory card: Create a folder on the memory card. Name it anything other than Music (the phone will automatically create a Music folder which can not be used as ringtones). Once you insert your card into your phone, the tunes should come up when you open your ringtone menu!
Hope this helps! Good luck! :)
Dec 30, 2007 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
165 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
