Question about Acer Aspire 5920-6727 Notebook
Logitech Remote controll not updating using Vista
I am getting an error everytime I try to update my Remote Control with my Acer laptop with Windows Vista. But using windows xp on my old computer I can update it with no problems. Here is the what I get on my remote software. I am getting to Step 2 of 4 Applying settings at 80 % using a an Acer >> Computer with Windows Vista. >> >> this is the message I get >> >> Step failed Updating region : 0x10a00102 - The information was not >> sent. Check your USB cable and try again. If the problem persists, >> contact customer service. >> >> This is the flow >> Starting communication - Successful >> Estimating time to update remote control >> Estimated time to update remote control : 1 minutes >> Estimating time to update remote control - Successful >> Updating region >> Uploading data: 1 attempt(s) >> Uploading data: 2 attempt(s) >> Updating region : 0x10a00102 - The information was not sent. Check >> your USB cable and try again. If the problem persists, contact >> customer service. >> Finished >> I have been working with logitech for some time now and can not find the problem. I have disabled AVG Windows Defender I turned off auto scan and ignore on alert actions. Firewall was turned off Might you have some ideas? Regards: Phil
mspcrepair
  • 169 Answers
SOURCE: acer 5570
Several things you can try...first, if System Restore is enabled (not recommended because viruses love to eat and grow in there), boot into Safe Mode (F8 at startup). If you can get into safe mode, go to Start, Programs, Accessories, System Tools, System Restore ...the SP update automatically creates a restore point before it begins (about the only thing that Microsoft actually got right!), and you should be able to select that restore point and go back to before you ran the update.
If that does not work, or you cannot get into safe mode, then you will need to run a Windows repair using your original Windows CD or factory recovery disc(s). Make sure to run a "repair", not a "clean install", else you will lose all your data. (if you don't care about saving data, I recommend a clean install).
If the repair doesn't work, your only real choice is to do a clean install, following the steps just above. However, you will lose all your documents, so if they are important to you, take your computer to a PC service tech or facility and have them backup your files first. It'll cost you, but probably not that much. I normally charge my clients $60/hr to backup their data, and usually it only takes about 30 minutes for 1-5GB of data.
After that (or without that), run the Windows "clean" install and you're back in business!
Hope this helps - remember to rate :)
Scott
Posted on Oct 02, 2008
gink0
  • 35 Answers
SOURCE: acer 5920 acer erecovery app crash after windows update
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
1s14
Posted on Jan 06, 2009
  • 50 Answers
SOURCE: laptop start up error
When the computer starts up press F8 repeatedly to enter the windows startup options. Try using Last Known Good Configuration and see if it goes in. If not, try safe mode - if it goes in with safe mode perform a diskcheck and do a system restore to when last working.
If not post again - there should be another string of numbers after STOP and before the Brackets in the format 0x000000?? - this code if google searched will tell you what the STOP ERROR is being caused by (google STOP ERROR 0x000000??).
Posted on Jul 24, 2009
  • 157 Answers
SOURCE: Acer aspire 6920 startup problem (Windows Error Recovery)
You could try booting up in safe mode by pressing F8 if you haven't already. OR, if you have the Windows operating system disc, you might try to boot off of that, or a system recovery disc. You may lose a few files, but hopefully that will get you up and running. Hope this helps!
Posted on Nov 09, 2009
LaptopExpert
  • 458 Answers
SOURCE: Acer Aspire One Netbook wireless internet connectivity problem
Try Resetting Your Wireless Router.. turn it off then back on
then run a repair on your wireless network
Posted on Nov 15, 2009
Error code 800fo900 windows vista
To download and install the System Update Readiness Tool, follow the steps below:
1. Click Start
Collapse the imageExpand this image
, and click Control Panel.
2. If you use Windows 7, click System and Security. If you use Windows Vista, click Security.
3. Under Windows Update, click Check for updates.
4. The System Update Readiness Tool (KB947821) is offered, only when
5. Click Install updates.
hope this helps
Jul 14, 2012 | HP Compaq Presario SR5010 Desktop PC...
Everytime I do a windows update, it either crashes or hangs on "shutting down" (after leaving it on all night!). Then I lose everything. Help!
you have to be more spacific on what you are doing and what os you are using. Are you using Windows 7 or Vista. If you are using vista, Dont. upgrade to windows 7, it's worth it. but everything else aside, try different ways of installing the updates. you can download the updates manually and install them other then just letting automatic updates do everything.
May 09, 2011 | Acer Extensa EX4420-5239 Notebook
My notebook is requesting to update my windows. how to update?
Hi, you haven't said what operating you have but try this, select automatic updates after clicking the start button. If not go to windows update home site and it will scan your computer for the latest updates.
Hope this helps
Aug 05, 2010 | Sony Computers & Internet
Where do i get software update for logitech 670?
First, you´ll need to install Logitech Harmony basic software for your remote.
For Windows XP: http://www.logitech.com/index.cfm/440/377&hub=1&cl=br,pt?osid=1&file=http%3A%2F%2Fwww.logitech.com%2Fpub%2Ftechsupport%2Fharmony%2FLogitechHarmonyRemote7.7.0-WIN-x86.exe
Windows Vista: http://www.logitech.com/index.cfm/440/377&hub=1&cl=br,pt?osid=13&file=http%3A%2F%2Fwww.logitech.com%2Fpub%2Ftechsupport%2Fharmony%2FLogitechHarmonyRemote7.7.0-WIN-x86.exe
After installation, connect your remote to USB port and follow instructions to update it. There is options to update the basic software and firmware as well.
Dec 29, 2009 | Logitech Harmony 520 LCD Remote Control
Harmony 520 update problems says error sending data
update your Logitech harmony software, then log in and update your firmware.
Also, if this continues, try using another USB cable or connecting at the back of the computer where the usb connection is direct to the motherboard
Jan 11, 2009 | Logitech Harmony 520 LCD Remote Control
My Acer Orbit cam is not functionly well
Try to update it with the latest updates using windows update feature ...
Nov 16, 2008 | Acer Aspire 5100 Notebook
My acer aspire 5520 laptop wont work after installing windows vista service pack 1
try this >> when you turn on your pc press f8 then choose "last known good configuration"
Oct 23, 2008 | Acer Aspire 5520-5908 Notebook
No Audio Output Device is Installed
sound card is a hardware buy it at computer shop
Aug 14, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Update my remote - Doesnt work
You might want to try turning off any firewalls before you open the Logitech program.
Apr 05, 2008 | Logitech Harmony 880 LCD Remote Control
Acer Aspire 5920-6727 Notebook Logo
886 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
