cressida blower assy, w/shroud. heating & air conditioning - Logo
e
erwin kiekopf Posted on Jan 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cnnection diagram for Car radio
I need a Connection plan for a Toyota Car radio Model No.86120-2A110 it was fitted to cresida GLi6 and is fitted with a Casset Tape Please Help
Mark Cunningham
Level 2:
New Friend:
  • Expert 44 Answers
  • Posted on Apr 13, 2014
Mark Cunningham
Expert
Level 2:
New Friend:
Answers
44
Questions
0
Helped
11668
Points
105
Have you searched a Toyota forum? Or that number in google?
Vacuum pipes location on toyota cresida 2.8i twin cam
Go to the given link and get all you want with pictures and diagram http://toolsnyou.com/
I need car stereo diagram for sony cdx Gt 100 and car stereo diagram for 98 toyota corolla and help me match colors both radio
Sony wiring diagrams are available from the support section of the Sony website.
The car wiring diagram would be helpful but I advise you not to slavishly follow it without independently checking and verifying the function of each wire yourself.
I advise you to check the suitability of the intended radio for the intended car. Some radios aren't suitable for some cars (when using the existing wiring).
It was a Sony radio a customer instructed me to fit to a Fiat Punto which soon suffered a completely discharged battery. When I checked the Sony website there was a warning not to fit to that car.
I HAVE A PROBLEM WITH TOYOTA GLI6 ECU BOX.I SWAPPED THE ENGINGES NOW MY PROBLEM IS THE ECU WIRING,I WANT TO KNOW HOW MY IM GOING TO CONNECT THE ECU WIRES TO THE OLD TOYOTA GL.
Different engine means a different ECU and a different wiring harness from the original in the car not to mention other items. (Never a good idea to try and fit a different engine from the original given the complex electronics). You need to plan the feasibility of these kinds of engine swaps before you decide on doing it. You will now need to employ a professional to work out the wiring but you might have a problem finding a competent mechanic willing to take on the task which will be complex and time consuming.
1helpful
Is there a common problem with the wiring/parts of the horn circuit on 1982 Toyota Cresida ?
horns get water inside the diaphragm and rust solid and a car of that vintage ,that would be a good assumption
use a multimeter and place it in volt mode and read if there is power to the horn terminal
if there is replace the horns.
Problem starting car
Sounds like a corroded connection somewhere, start with the easy ones, battery, cables, coil and starter connections at the starter. also check the distributer cap and rotor if the engine cranks but wont start. good luck with that, glad 2 c someone keeping the old toyotas running, u should be able to get close to 275k mi. out of it
Need wiring diagram for 1994 Nissan Mistral radio
Posts Related to Radio and Player Wiring Diagram of Toyota Camry Model Year 1994. Please check this website when you get chance.------------------------------------------------------------------
toyota tis
2answers
How do i install a pioneer radio without the instructions
Aftermarket radios have a standard wiring color set. Tell me the radio model and car year/model and I can send you the exact connection scheme.
No wiring diagram for radio/cassette
If you identify the MAKE of existing radio , then you can work out which wire belongs to which cnnection somewhere on this site
.http://www.tehnomagazin.com/Auto-radio-car-connector/NISSAN-Car-Radio-Wiring-Connector.htm
Top Toyota Vehicle Parts & Accessories Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
