Question about Epson Stylus Photo R200 InkJet Printer
Paper Feed problem
I have an epson r210 and suddenly it will not feed paper. It keeps trying but it seems to not be gripping correctly. any ideas what could be wrong ?
  • Epson Master
  • 511 Answers
Paper feeder problem. Replace it. Or just replace pick up rubber at paper feeder mechanic
Posted on Jun 03, 2009
Keeps saying paper out cassette 1
Sometimes the rollers that take the top paper into the printer get a little worn or shiny and doesn't grip so well try helping it at the point when you hear it start to try and take the feed in by holding the top piece of paper and easing into the printer feed.
Mar 22, 2015 | Epson Expression Premium XP 820 Wireless
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Espon RX500 feeds intermidantly
and i sense that you're familiar with the product too.
not feeding the paper right at random, tried a couple or more paper, diff types of paper, made sure paper is not crumpled.
worth trying, clean the visible part of the paper grabbing mech - look straight down at the paper loading area.
check warranty and go for it else - staight answer get a new one - internal paper feed mechanizm aint working as how it is designed.
Sep 15, 2008 | Epson Stylus RX500 All-In-One InkJet...
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Paper jam
some times you need to clean the rubber rollers inside the printer with alcohol. this helps them to better grip the paper.
also before you put the paper into the printer you need to fan it really good to separate the papers. otherwise they stick to gether and take more than one at a time. thus , paperjam
Mar 06, 2008 | Epson Stylus Photo R2400 InkJet Printer
EPSON STYLUS PHOTO RX425, PAPER PROBLEM
disconnect the printer from the computer:
>manually feed paper using the paper feed button.
>observe, if the printer pulls only one side of the paper then it´s a hardware issue
Jan 01, 2008 | Office Equipment & Supplies
Loading paper in fax machine
Relax ti mal- the rollers are not picking up the paper because they are dirty or worn out.
Try this clean the rollers with alcohol and try, are the rollers smooth or do they have a rough feel? if smooth replace and it should be good as new.
Good luck
Nov 29, 2007 | Philips PPF-575 Plain Paper Inkjet Fax
Epson c20ux paper wont feed into printer
you wont have to feed the paper just try to print and it'll feed the paper automatically. but if there is a problem in mechanism that will be your problem, you'll have to bring it or just call a service tech.
Sep 08, 2007 | Epson Stylus C20UX InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
339 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
