Question about Philips TP2785C 27" TV
Vertical interference and black/red boxes appearing on my Philips
Hi, my 29PT6361 Philips Tv has started intermittently going into vertical spasm - sometimes for a second - other times for a minute - prior to this happening there appears to be little boxes of red and black appearing on the screen - or sometimes on their own. If you could give me an idea of what could be wrong I would be most grateful before I throw something at it!! Thankyou so much
  • 3 more comments
  • jvntak Jun 03, 2009
    Thankyou for that - it's a funny thing that when we stamp in front of the tv it corrects itself - that made us think it may be an aerial connection problem?
    The lines are actually horizontal but travelling vertically up and down the screen with the black & white squares (pixels I suppose) being intermittent prior to the vertically moving lines. Why is that when we jump in front of the tv it all stops and the picture is perfect?
    Hi, yes I have disconnected dvd/vcr and set top box and the tv is still doing the same thing.
    Just watched a video taped this afternoon and the sound is now disappearing intermittently.
    Is that what usually happens with the high voltage capacitor problem?
  • jvntak Jun 04, 2009
    Thankyou for your comments! Yes it still does the same thing even when dvd/vcr is disconnected and set top box. Yesterday we taped a show and the sound has disappeared on half the tape - would you think that would happen with the high voltage problem as well?
  • jvntak Jun 07, 2009
    Thankyou - that sounds reasonable as it certainly looks like some sort of electrical interference problem - as yesterday it hardly occurred at all - would it be someone in the local area perhaps using some electrical machinery?
    Sergeant:
    Champion:
  • 226 Answers
If you have a amature radio operator or tv station transmittor near you this will most likly be the problem ,your reception may be TOO good.if it is a older style check for hold knobs on the back.if all else fails try a standard antenna on reguler tv if it works this way get with your tv provider and tell them yuor situation.they should fix it for you.hope this helped.
Posted on Jun 07, 2009
    President:
  • 1,952 Answers
Www.p4c.philips.com/files/t/tp2785c/tp2785c_dfu_aen.pdf -
Posted on Jun 04, 2009
  • mohammed marika thambi
    mohammed marika thambi Jun 04, 2009
    What is picture like if you change screen size to 4-3 is this picture
    size ok & fault only shows in the wide screen formats.
    it is due to poor focusing
    please check
    1 set with focus control fitted on flyback transformer,
    2 check focus control wire comes to crt base is loose or some foreign material deposited on it.
    3 crt base loose contact.
    4 if tv is old then there is a possibility of crt is getting weak.
    if you are not a technical person do not open set as tv has very high voltage inside.
    hope this will help.
  • 67 Answers
Try keeping the tv off for a few days so it can rest then try to turn it on again if it still does that try going to the manual for any hints
Posted on Jun 03, 2009
    President:
  • 1,734 Answers
Sounds like the high voltage line is rising. I have seen a few sets,
including Philips, where the blank screen seems to bring up retrace
lines and the like. I'd replace any high voltage capacitors you see -
a few may be bulging or showing their silver after the coloured label
has shrunk with heat.
Incidentally, are symptoms the same with and without a device
connected to the input? Maybe the interruption of the channel change
or absence of any sync signal is producing some problem in the Line
output drive / stage.
    Scholar:
  • 100 Answers
This is central video processor problem. It obviously starts behaving like that after some time as it getting warmer.
You would need to contact TV manufacturer for service if TV is still in warranty, otherwise repair would be rather costly.
While watching our 42 inch Philips Plasma tv the other day, a vertical black bar showed on the screen. Based upon the fact that it appears no matter the input (HDMI, composite etc. We turned off the tv...
If you get the black bar and it is vertical, not horizontal and it is on every input, your panel has failed. It is more economical to buy new than replace the panel. Try a Sony. Mine rocks.
(If the bar is horizontal, it may be an empty closed caption box)
Aug 09, 2010 | Televison & Video
NTV Scree
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 28, 2010 | Televison & Video
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Pink (Magenta)vertical line appears on the screen
Vertical magenta lines could be a symptom of a loose connection to the optical assembly,or a source of interference. Try resetting the TV first - unplug from wall socket for about 2 hours, replug, and see if it works.
Also check the cables/connections from your cable box, etc and see if the issue can be resolved by manipulating the wires. Could be a loose connection..
Oct 03, 2008 | Philips Televison & Video
Phillips plasma 42 in tv thin
malfunction of the vertical output integrated circuit
Dec 22, 2007 | Philips E-Box FTR9965 DTV Receiver
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Philips TP2785C 27" TV Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
