Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Not freezing or cooling and is clicking on and off
Unit clicks on and off but is not cooling or freezing? Not sure what's wrong? Not freezing or cooling and is clicking on and off but ptc relay is not same
    Problem Solver:
  • 9 Answers
Pls check the thermostate,and the setting,it may be narrow .you can get the same relay which you get with the unit.check the voltage near the socket.check for loose connection in the relay and compresor terminal and thermostate.
Posted on Jun 03, 2009
Hi, I have an LG refrigerator that has stopped cooling altogether.
its the ptc overload/relay,but make sure to check the compressors motor winding resistance on both start and run windings theres 3 terminal pins where the ptc overload attaches the single pin above or below the other 2 pin terminals is the common terminal,check for 8-11 ohms between the common and each of the other 2 terminals,then if no resistance or zero resistance then its the compressor,also check from the compressor case to each terminal at a time to make sure compressor isn't grounded to the case
Jan 07, 2013 | Refrigerators
Fridge not getting cool and i do not hear it running but has clicking sound
replace the ptc overload/relay mounted on the side of the compressor in the rear area of the unit,it helps start and operate the unit,thats where the clicking sound is coming from
Oct 16, 2012 | Magic Chef MCBR360HW 3.6 cu. ft. Compact...
Fan blowing warm air food not freezeing
the ptc overload/relay on the compressors dead so the compressor cannot start,therefore the unit cannot cool,replace the ptc and it will run again
Aug 03, 2011 | Freezers
There is a clicking sound and its not cooling or freezeing
its your ptc overload relay on the compressor,its trying to restart the compressor,it is worn out,merely unplug it off the compressor and replace it
Apr 10, 2011 | GE Refrigerators
Refrigerator not cooling, freezer not freezing. Can hear fan running continuouisly and an occasional buzzing noise that lasts for about 20 seconds then ends with a clicking sound.
the buzzing and click noise is the ptc overload relay on the compressor,its bad,unplug it off the compressor and obtain a replacement and plug in the new one
Mar 24, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Samsung american fridge freezer, not freezing, clicking noise at the back of the fridge
Your PTC relay is bad and needs to be replaced. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken If the part is way expensive you can replace with a 3 in 1 relay for refrigerators alot cheapier and work just as good.
Jan 31, 2010 | Samsung Refrigerators
Your PTC relay is bad and needs to be replaced. That clicking sound you are hearing is the overload failing to hold and then clicks off.
May 03, 2009 | Frigidaire FRS26H5AS Side by Side...
Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
Feb 02, 2009 | Kenmore 53642 / 53644 Side by Side...
My Frig is not cooling
your ptc relay on the compressor when they go out they make a clicking noise. The compressor will quit and little bit later might try to come back on and click again. You need a new ptc relay. It is on the compressor little black box just unplug your refrigerator and pull the relay off. undo the wires and get a new one. Kinda staight forward compressor has 3 prongs that the relay plugs into.
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
254 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
