NOT BLOWING COLD , DO NOT HAVE THE MANUAL ANYMORE
I HAVE A DWC-054R A/C UNIT THAT CAME WITH THE HOUSE. IT DOES NOT SEEM TO BLOW COLD AIR ANY MORE. WHAT CAN I DO TO FIX THE PROBLEM?
  • worldgpfan Jun 03, 2009
    thanks, i will give it a try.
    Problem Solver:
  • 9 Answers
Check wheather the fan is working .check the pre-filter it may be clogged.check the rated amps it drawing if the unit is working .check the blower/blade of the fan motor.
Posted on Jun 03, 2009
Hi. I need help fixing my urka-a042jk10e Air Conditioner please. It's not blowing any air up thru the vents and my house is 97 degrees!
Possible that the compressor is not running. Call a service tech. Could be a run capacitor bad, stuck reverse valve or even a shot compressor.
Jul 30, 2016 | Heating & Cooling
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Unit is blowing out mist.
If it is cooling properly, and the mist does not have a chemical odor, and the area to be cooled is hot and humid, this can be expected as it is due to high humidity, and a cold coil on the unit, (kind of the same thing that couses clouds in the sky)...if it has a chemical smell sounds like a refrigerant leak. hope this helps
Dan
Aug 28, 2011 | Daewoo DWC-084R Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
Visible vapors blowing in
That is normal and nothing to worry about..
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 08, 2010 | Daewoo DWC-052C Air Conditioner
Not blowing cold air anymore
Possibly dirty evaporator coil or condenser coil. Maybe dirty filters. Also could be low on refrigerant charge.
May 17, 2010 | GE AJCQ08ACB Air Conditioner
When i have the heater/defroster on the heater below blows cold air while the defrost blows hot. when i switch to just defrost the bottom heater stays on and blows cold air. when i have front dash and...
It sounds like you have a blend air door stuck. This is in the housing of the heater a/c blower unit under the passenger side of the dash. There is a motor on the top of the housing that could possibly be stuck or on working.
May 10, 2009 | 2003 Dodge Durango
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
