Question about i-mate K-jam Smartphone
Display problem my i-mate k-jam display loses or changes colors when i slide open the display to use the touch pad.  sometimes it will proceed to full white then back to color.  but i began to notice a distortion of color on the screen.  it would only occur when i slid the display open to use the touch pad.  now i think it is beginning to distort slightly in the closed position.  any suggestions on what the problem may be and how to resolve it?  thank you! james
  • Anonymous Mar 03, 2008
    display goes blank
    Sniper:
  • 146 Answers
Login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
States scanner failer; turn off ;then on; have
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
      NOTE: Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the productFollow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 26, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Automatic document feeder does not work-- does not pick up paper
Yes, I had the same problem, and I finally got it to work. I took the printer apart and removed any paper that was stuck in the ADF in the top and it in the duplex in the back. I then did a reset and it still would not work. What I did was to turn off the printer by hitting the power button, unplug the power cable and let it sit for while so it loses its memory. then follow the instructions on HP web site on how to do a power cycle.
In my case it still would not work, so I turned the printer off for about an hour so the memory would be erased. Then after I got it on I did a factory reset. - press setup, press 6, then press 3.
I'm so excited, my printer is now working again. HP would not repair it for me and would only send me a newer model, but the older ones are easier to repair and parts are available. My email address is: edwina.mann@comcast.net . Good luck.
May 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Calibration problem
the problem in the touch pad sensor cercuit,
try to fix it or change it with a new one
Nov 27, 2007 | i-mate JAM Pocket PC
Touch Pad is not working+
have you rebooted the unit? rain will kill the touch panel and its connector.
Nov 09, 2007 | i-mate JAM Pocket PC
I have a jammed cartridge, what can I do
The last two MFP printers brought into my shop had problems from their original setup and opening. Check the inside, anywhere that the paper path or cartridge line touches, make sure there are no small shards of plastic or remaining packing materials like tape or cardboard flakes deep in the printer. There are also small jam sensors that protrude very little from the paper path that if knocked over a little bit can become loose and ironically cause jams.
Oct 23, 2007 | Canon PIXMA MP130 All-In-One InkJet...
I-mate jam screen
First of all you need to make a "Hard" restart (thats usually cleans up also the memory so perheps you'd better back it up)You can make it by taking out the battery and there I think you should have the restart button,then go into the menu and try to re-configure your screen touch, Hope that'll help
Apr 12, 2007 | i-mate JAM Pocket PC
i-mate K-jam Smartphone Logo
280 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
