My microwave/convection shuts off after 59 seconds. One guy suggested I replace circuit board. Another guy says it could be several things. Any specific advice?
-   Sharp R-93ST shuts off after 59 seconds!
-   Guest
Jan 27, 2009
-   Same 59 seconds. In 2004 Holiday Rambler Scepter. Service tech was just here. Says Circuit board bad. Quote to fix $387.62. Ouch!! Did anyone get there's fixed? What was cause and what was fix. I can find the board for $132, was quoted $218 by tech for part $155 for labor. I took mine apart, (I watched the tech). Looks like board just unplugs in several places. Should be easy to replace. IF THAT IS THE PROBLEM. Pain in the **** pushing start button every 59 seconds.
-   rphilljr48
Jan 24, 2009
-   my microwave stops after 59 seconds no matter what time I put in
-   jbarnes431
Jan 06, 2009
-   I have the same problem. How do I get to the damper assembly. Do I need to take the unit down first?
-   pgovernali
Sep 09, 2008
-   Same 59 second issue with an R-1874 installed in a 2004 Monaco Diplomat Motor Home. Issue started between outings. Just looking into the possible cause and found your website. The unit was built in 11/2003.-   jimtomfulton
My problem turned out to be the control switch which was a $15 bill plus another $90 in labor. I had to remove the microwave from the motor home and take it in for repair. The removal can also be handled through the motor home dealership and the cost will be higher.
In the next couple weeks mine will be going into a shop that only repairs microwaves. I can't get it unmounted from my motorhome so that has to be solved first. I will post back here when I get the final fix.
Comments:
Jan 03, 2009
- My problem turned out to be the damper motor.
$14.95 for the motor.
Total bill was $106.18 which included removing from motorhome, repairing and then reinstalling in the motorhome.
Damper assy is somewhere inside the microwave. Not too easy to get to I assume.
We recently acquired this microwave at no cost. It reportedly was "new in box" tho...
(More)
We recently acquired this microwave at no cost. It reportedly was "new in box" tho manufacture date is 2007. When plugged in it doesn't power up. What would be the first couple steps we would take to troubleshoot this?
Hi - Can anybody tell me where in the UK I can source parts for a faulty Sharp R-1874 Convection...
(More)
Hi - Can anybody tell me where in the UK I can source parts for a faulty Sharp R-1874 Convection Oven - The US based suppliers say they cannot supply to overseas customers! help!
My Sharp R-1874/1875 Microwave/Convection oven had the microwave quit. How can I fix it? Is it...
(More)
My Sharp R-1874/1875 Microwave/Convection oven had the microwave quit. How can I fix it? Is it worth fixing? Thanks, Jim
I am having the same problem shutting off after 59 sec. Sharp R-1874 model. Did anyone replace the control unit? That is what we were told to do but want to make sure this is the part we need to replace because the costs is about $150.00.
Same problem as those listed. Shuts off in convec or Micro after 59 secs. Also in a motor home. What co-incidances that there should be so many in motorhomes. Mine is a Monaco Windsor 2004 40' PST.
I am now looking for parts before I pull it out. Any suggestions.
Mad Hatter
I have the same problem with microwave shuts of after 59 sec. It is a built-in, in a 2006 hoilday rambler, we tried to take the front cover off, and this is impossible how do you remove?
Same problem noted on my SHARP R-937 (R-93ST).
I am not sure yet whether this model has a Damper assy installed....?
The 59 seconds issue could be a timer IC/uProcessor on its control panel?
My other suspect is the timer/weight setting knob wich is a Digital Control Potmeter rather than just a conventional analog?
Comment by Guest, posted on May 06, 2008
Followed FixYa suggestion, Microwave is back, mounted and working great. Cost total of 16 dollars for new damper motor and a couple of hours of messing around...Thank you so much, and the wife thanks you. Guest.
Comment by Guest, posted on Apr 25, 2008
Shuts down in 59 seconds. Checked with Sharp and a dealer was suggested.
I have the same problem with it shutting off after 59 seconds. We have a Sharp R-1874 Convection. We are in a motorhome. Recirculating non-vented. Any help?
I have the same 59 second problem. Just exactly where is the damper assy? As I look at the front of the unit is it on the left or right side? My microwave is mounted over the stove in a motorhome. Do I need to remove it to repair the damper assy?
Comment by Guest, posted on Jan 21, 2008
Mine also only runs 59 seconds. Your tip about the damper...where is the damper assy?
